5.8 351w
firstford
would the neutral safety switch make my truck cut off when put in Ror D and acclerate
Roadkill
Killeen, TX
No, the neutral safety switch interupts power to the starter relay (or solenoid, as some call it). If the starter cranks in P or N and not in other gears, then it is functioning properly.
F
firstford
Thanks would you have any idea what would make it cut off like that. Long as its in park it stays on soon as i put in RorD GOES RIGHT OFF.
Could be a variety of problems, the first one that comes to mind is maybe your torque convertor is screwed.
Roadkill
Killeen, TX
Yardape brings up a good point. Did you have any problems before the tranny swap? If not, where did the tranny come from? Do you know for a fact that it is in good working order and that everything was put back together correctly?
Roadkill
Killeen, TX
I don't know where I got the idea that you had swapped transmissions since you made no mention of a swap in either of your posts. Maybe I got you confused with someone else. Disregard my questions on the subject, unless of course, you did swap trannys. In which case I must have some sort of ESP powers. Wanna bet on some games? :D /emoticons/[email protected] 2x" width="20" height="20" />
F
firstford
I guess your esp is screwed like my truck the tranny was orginal far as i now set it up for about a year drove it 2 or 3 times now all **** broke lose.
F
firstford
Surprise to me the dern thing was just out of transmission fluid go figure.Thanks for the info.
Coastersfwb
