5.0 ** Oil Pan?
Shwagy357
Im in the process of doing a 93 mustang 5.0 engine conversion, and i was wondering if i could use the mustang oil pan on my 77 bronco. if not what do i have to modify on my bronco oil pan
Ice Man 860
Eastern CT
the fox body stangs have a double sump oilpan... it might not work on your 77. im not sure how the 5.0 mounts in the eb's but im pretty sure they dont use the double sump. check broncograveyard.com
STLKIKN
Calgary Alberta
If your truck has anything larger than a 2" lft you should have no problems with the 5.0 pan. If you don't have any lift I wouldn't recommend it, the pan may contact the diff under compression. (front right corner of the rear sump, if I had a digi cam I could show you the "self clearancing" on mine!!))
LanceG
What about an oilpan from a '68 Galaxie? I have a 1970 Bronco. The original 302 is long gone so I have one from a '68 Galaxie. I plan on putting a 3-4 inch lift on it. Thanks!
Bronc76
I think both are front sump pans so you should have no problem.
LanceG
Thanks! I was thinking that all early Broncos had the double **** to clear the diff.
Bronc76
My '76 only has one **** and I know its original, that's why I think it will work, plus with your lift you should not have any clearance problems.
"What about an oilpan from a '68 Galaxie?"
Hmmmmm... I was under the impression the pan & pick-up tube/screen were different on the Bronco due to steep downhill runs. :unsure:
Might be better served checking with the EB stores just to be sure.. :-B
Staff online
Wdtdls
