4x4 Light always on
Pr0jeCt
I recently went on a trip to the airport, about a 2 hour drive. When i got to the parking garage i noticed the 4x4 light was lit up on the dash, and on the pushbutton switch. oh, 95 bronco is what i drive. I currently dont even have the front driveshaft installed so its not a big deal if its locked in 4x because well, it wont do much.. But im wondering WHY the light is stuck on all of a sudden?. Last august i had to pull the tranny to do the front seal and it has been fine up untill my recent trip.
Any clue as to why it is stuck on? is this an indicator of a common problem? any help is much appreciated.
yo P,
Indicator Lights Don't Register the Correct Information
Ranger, Bronco II and Explorer have indicator lights in two locations. There are lights on the dash and LED indicator lights in the switches. Other vehicles have only the dash lights. If the dash lights on any vehicle don't respond, look for no power or a burned out bulb.
If the lights are on all the time, look for a short to ground. Also check to see if the shift control module is activating them all...this is a malfunction.
If the LED lights, in the buttons, remain on all the time, first check to see if the dash lights are also on. If the dash lights are not on, this means that the dash lights have burned out. The LED lights are on because a low current is still passing across, enough to light the LED.
If no lights illuminate as you go through the shifts and ground power and bulbs are good, then the module is at fault or the motor has stopped at an intermediate point.
All this & much more is in:
1356 Electric Shift Troubleshooting & Repair - BEST PROCESS!
Source: by Ford via Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/724137
GL!
P
Pr0jeCt
Thank you for all the information. Ill attempt to find the culprit when i have some extra time.
yw, &
thank Ford for giving us the scoop and Steve for passing it on
Let us know how it goes.
Frankie
Monroe NY
miesk5 are you on FSB too? dont you have the lifted black f150 w/ the 300?
and i noticed my light would be on too but im not in 4wd but it was dim. when i pushed it it was engaged and really lit up.
Frankie, nest are the ground location;
Grounds 10-5
Behind bottom of RH cowl panel (F7)
Component
Air Bag Diagnostic Monitor
Electronic Shift Control Module
Instrument Cluster
Programmable Speedometer/Odometer Module (PSOM)
Remote/Keyless Entry Module
Speed Control Servo/Amplifier Assembly
from my 96's EVTM/PCED Manual
