4X4 Issues 205 T-case
RattleCanned79
Im having problems with getting my 79 bronco with the 205 t-case to shift into low range...
whats the route to take...to check/make sure its in low range?
it seems when i have it in 4 high or 2 high then go to low range the is no change in ratio but as far as feel in the lever it shifts into all stages and N does work as well...im at a lose here cuz it just doesnt seem to be low range at all.
muddrivermike
Texas Arp
You might have an internal problem in the case...Check to make sure though that the flat shift bar that comes off your shifter is locked into both shift rails coming out of the case..If they are then you might have to tear the case apart and rebuild it...
R
RattleCanned79
Yes they are connected, I pulled the shift lever off where it mounts to the tranny...how easy
should the rails move into and out of the case? Also any clue as what factory gears in the
third member are? 3.25 to 3.50 is all I could find in my searching is that correct?
R
RattleCanned79
So I know for sure the case is not going in low range, going to fix the problem this week hopefully but if anyone has any tips or trick feel free to let me know thanx...Aka Squishy!
fred tyler
