fourbybuilder
In 1989 Ford never offered the 351w with the AOD trans . The Problem I have ran in to with this conversion is That the 351 w's fly wheel is offset to far back in turn this ate the pump out of a brand new trans and welded the high gear clutches together, Because it forced the torque converter in to the pump. My question is this the 302/5.0 's fly wheel has the same tooth count and diameter as the 351w's but is set aprox 60-70 thousandths further in. Will this correct the problem or do I need to go to A C6. I would like to keep the aod because of the over drive gear. Ths has been a very expensive oversight any help I thank you for..
