1995 Eddie Bauer Remodel
G
GatorGirl
Guest
We are finally remodeling my 1995 Eddie Bauer green. I am the original owner. My husband and 2 children have all lovingly driven her and now she’s in need of a new do & outfit. She’s in the shop getting painted Royal Blue and pin striped Orange. A small Gator will grace her sides in the pin stripping. If I knew how to upload photos I would. We go in about every week to see the process and snap pics.
Have been ordering a zillion parts. Carpet and door panels today.
I am in need of the dash trim pads (left, right & long right) and can only find used. Wanted the original silver or wood veneered ones but little to no luck. Open to suggestions.
Yo GatorGirl,
A question, has speed control, if equipped recall work completed by dealership? Call local dealer or register and view status @ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ... have VIN ready.
"Summary: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND THEN OVERHEAT, SMOKE, OR BURN. THIS COULD RESULT IN AN UNDERHOOD FIRE."
See this guide by jowens1126 to confirm recall status @ https://www.fullsizebronco.com/forum/23-technical-write-ups/457065-93-94-96-cruise-control-recalls-repair.html#post6530073
The dash trim pads may be available via obsolete parts suppliers, using Ford long version part numbers which may still be available at a local Ford dealership.
Obsolete Parts Suppliers:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
https://nospartsltd.com
Typical dealership Parts Catalog; 87-91 & 92-96 Bronco (Partial)  Source: by Ford via me, but nada for what you need @ https://www.supermotors.net/registry/3549/77108-2
Included are:
INDEX, paint codes, front bumper, PAGE 833
ABS module, sensor, decel switch, etc., air bag module, monitor, sensor, etc., underhood dimensions in mm, cruise control, wheels, frame, PAGE 836
front suspension, PAGE 837
grille, front lamps, headlight, hood, engine cooling: radiator, fan, water pump, shroud, page 834
paint stripes incl. NITE, HVAC, fender, PAGE 835
steering column & linkage, gear, pump, wheel & horn switch, Page 838
steering cont'd, ignition switch, Engine, Page 839
engine & trans CONT'D, air cleaner, alternator, battery cables & tray, air intake, hood, ignition, Emissions Page 840
center console, dash, instrument panel, cowl, wiper, PAGE 841
front floor pan, 92-96 seat belt (bucket front & rear bench), interior & exterior door trim, cab step, page 842
door CONT'D, cab roof, camper top, overhead console, page 843
tailgate, quarter glass, interior & exterior trim, PAGE 844
fuel tank, rear suspension, 8.8, floor pan, glass, tire carrier, rear lamps, high mtd. stop lamp, page 845
license lamp, bumpers, grille, CONT'D, PAGE, 846
engine & transmission CONT'D, exhaust & catalytic converter, air intake, hood, HVAC parts & R-12 refrigerant capacities, CONT'D, Page 848
fender, paint stripes, ext trim, wheels, CONT'D, page 849
wheels, front suspension, steering linkage/column, CONT'D, PAGE 850
frame, strg column, windshield, cowl & dash, CONT'D PAGE 851
instr panel, but none for 95, ctr console, front floor pan, interior door trim, seat belts (87-89 & 90-91 bucket & rear bench) , CONT'D, PAGE 852
glass, vent, cab roof, camper top, side quarter glass, quarter panel, CONT'D, PAGE 853
quarter panel, tailgate, rear suspension, 8.8, fuel tank, tire carrier, CONT'D Page 854
fuel tank, rear floor pan, lamps, rear bumper, CONT'D, PAGE 855 - end.
Here is the 1995 Bronco Dealer Brochure
Free registration for some wiring diagrams (86 through 96) and Technical Service Bulletins, (80 through 96) with Recalls, same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
 See attached pic on how to post pics or images, etc.
GL!
