1994 5.0L Weight
bmunson
Scarborough, Maine
Hi All,
I'm getting ready to pull the 302 EFI out of my 94 Bronco. A freind has a 750lb engine stand I can borrow, but I'm nervous about the weight limit. The best I've found is that the engine weighs approx. 480lbs, however, I don't know if thats with intake, exahuse, pumps, etc. Has anyone pulled a similar engine and mounted it on a 750lb stand, or know the gross weight with accessories? Appreciate your help!
You should be fine, make sure all the bolts are tight and it should be alright
