1993 Bronco Wont Shift please help
Bmarlowe30
Midland, Tx.
ok I have a 1993 Ford Bronco 4x4 with E4OD Transmission. When I shift it into drive it will not go into the lower gears. It stays in high unless you manually shift it into lower gears. Also the Speedometer is not working. I believe these issues are related.
When I bought this bronco it already had this problem and got no info from the previous owner. I have been working on it for over a year to no avail.
Here is what I have done so far
1.Replaced the speed sensor 3 times just to make sure I got a good part
2.Checked continuity through every wire in the transmission wiring harness
3.Replaced Transmission and Torque Converter
4.Transmission oil and filter
5.Replaced the Plug itself going to the speed sensor
6.Spun the wheels and checked the speed sensor with a volt meter and it checked out great
7.Replaced the neutral safety switch twice
8.Replaced Throttle Position Sensor
9.Replaced Engine wiring harness complete with fuse box
10.Replaced the Computer or ECU twice
11.New Instrument Cluster
12.Checked the tone ring in the rear differential
13.Checked continuity of the wires from the Speed Sensor on the rear Differential all the way to the plug at the firewall
14.Replaced all fuses
15.Replaced all light front and back and all work
16.Checked and repaired all vacuum hoses
17.Taken everything apart checking for pinched wires and none were found
I have a friend that has owned a Mechanic shop for over 30 years and has worked on my cars and our company vehicles and he cannot figure it out.
Also have a friend that is the best Transmission specialist here and he cant figure it out.
I love this bronco I just want it to be fixed..
Please I beg you someone help me out
Thanks
  Brian
Yo Brian,
I assume the cluster included a different PSOM (Speedo)?
Did you replace or bypass the 4WABS Control Module? "...A new light truck 4-Wheel ABS was introduced as standard equipment on the 93 Bronco, and it was revised in 94 on Broncos, requiring a different control module revision for 94 to 96 Broncos, compared to the original 93 Bronco module. The anti-lock brake electronic control module is located in the engine compartment behind the driver's side head lamp on a bracket mounted on the surface of the plastic fender apron. The anti-lock brake electronic control module monitors system operation during normal driving as well as during anti-lock braking.
***In addition, the anti-lock brake electronic control module provides a speed signal to the programmable speedometer/odometer module (PSOM) and to the E4OD via the PCM and for speed control ***
My 96's similar symptoms were almost the same until the 4WABS Module's microprocessors finally burnt-out. 2 yard Modules were bad so I jumpered the Module out as Turbo Ghost describes below.
My 96's same symptoms were erratic until the 4WABS Module's microprocessors finally burnt-out. I had one go bad and 2 yard Modules were also bad; so I jumpered the Module out as Steve & Turbo Ghost describes below.
To bypass the 4WABS module @ it's harness's connector & feed the ABS signal directly to the PSOM.
Disconnect module (under coolant recovery /ws washer tank) & in connector, jumper LG/Bk to LG/Y, and R/Pk to O/LB.
Module uses a 10mm bolt to hold the connector in place. Loosen the bolt (it doesn't come out, just loosens) and pull the connector from the module. Then jump the pins as shown in the pic and place the connector in a safe position so the jumpers won't get knocked loose while driving. Make sure the connections are good and clean and the jumpers are firmly in place. Contact cleaner will help. Then, drive the vehicle a short distance and you should immediately regain your speedometer/etc. If you do not, then your problem is NOT the module.
http://img.photobucket.com/albums/v252/turboghost/ABSConnectorw-jumpers.jpg
Here is more info, most of which you have done;
This problem could be caused by a # of things;
bad vehicle speed sensor (VSS) (also called ABS,, DSS sensor) on the 8.8 (rear differential)/ or corroded Connector/ wires inside connector; many NON-FORD MOTORCRAFT sensors ARE REPORTED DEFECTIVE BY OWNERS, such as;
"... The VSS was probably working fine the entire time (except the DOA Vatozone ones)..."
by ****-sidewards
"...Anyway, the autozone VSS looks almost identical to the ford VSS. They are both now made of plastic. You have to look very closely to see minor differences. However, the magnet inside does not budge in the ford part, no rattling noise at all. The Autozone part rattles when shaken, ie. the magnet has room to move inside the plastic housing.[/b]It's was a big lesson for me. Wrong readings from the VSS can cause so much E4OD problems...erratic shifting, late shifting, hard shifting, feeling like it was in neutral, as well as engine cutting off at stop lights---Even if it registers correct readings on your speedometer..."
Source: by bkne40d
"i installed a motorcraft speed sensor today (DY1123). i drove it all day today with numerous stops. i tried to make it fail by playing with the overdrive switch. it seems as though it was my failure by not buying a motorcraft sensor to begin with. i think the truck is fixed. shame on me for trusting BWD, i suppose. but also, shame on all parts stores for failing to list a speed sensor from motorcraft for my car! to my defense, there was no motorcraft number listed for my car at any of the parts stores. What i find most interesting is a potential indication of WHY the motorcraft is better, other than the labeling. below are pics of all three sensors next to each other. the difference seems to be in the size of the magnet/sensor in the motorcraft compared to the BWD part.
also, good on oreilly's for happily giving me a refund on the two BWD parts."
by dash_cam
or cruddy/damaged tone ring in the 8.8.
bad 4WABS Module - It is located below ws wiper fluid/coolant recovery tank. So, the connector can be corroded by leaking fluid
bad PSOM (Speedo)
bad wiring/shorts /connectors from VSS at firewall, at 4WABS Module and /or at PSOM and then onto the PCM
The locations of the connectors along the path from VSS to 4WABS and up to Instr Cluster & PSOM are;
C404 VSS On rear axle sensor (A7) Terminals: 02
C205 LH rear of engine compartment, in safety wall (Fire Wall) Terminals: 24 In-Line
C202F & M LH rear of engine compartment, in safety wall (A8) Terminal: 7 In-Line
C119 LH front corner of engine compartment on 4WABS control module (E10),Terminals: 40
O/LB to:
C252 Programmable Speedometer/Odometer Module (PSOM), Behind top LH side of I/P, on PSOM (A7) Terminal: 12 Color: B at Pins 4
LG/Y to Splice S107 Engine control sensor harness, from C119 near T/O to G101 (G101 RH side of Radiator support); to PSOM Pin 5
C202 F and M
and spliced to Ground G100 (BK)
G100 & G104 (tied together in diagram) G100 @ LH front of engine compartment, on upper radiator support
G100 Serves Component:
Fuel Pump Module
Inertia Fuel Shutoff
Misfire Sensor aka crankshaft position sensor
Misfire Sensor Shield
Output Shaft Speed (OSS) Sensor
Powertrain Control Module (PCM), 5.0L
G200 Behind bottom of RH cowl panel
Serves Component:
Air Bag Diagnostic Monitor
Electronic Shift Control Module
Instrument Cluster
Remote/Keyless Entry Module
Speed Control Servo/Amplifier Assembly
From PSOM Pin 7 (GY/BK) to Splice S246 Main harness, near T/O to speed control amplifier to
C185 PK/O @ PCM 5.0L Powertrain Control Module (PCM) LH side of safety wall, on powertrain control module (PCM) (C10) Terminal: 104 Color: GY
C185, 5.8L Powertrain Control Module (PCM) LH side of safety wall, on powertrain control module (PCM) (C10) Terminal: 104 Color: GY
C185 @PCM to C202 F and M
Splice 216 to Ground G200, Instrument Cluster ground is inside passenger side kick panel
and on to C185 @ PCM PIN 58 (GY/BK) and from Pin 46 to MLPS (TR) Pin 2
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19 @
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
And Post them here according to:
KOEO
KOER
Check Fuses 8 & 18 in Cab fuse block (lower left of dash by driver's left knee)
If no 12 v on Supply Side of each; look in Power Distribution Box (Located under the hood on the drivers side fenderwell, on driver's side of the air cleaner housing)
and check **** FUSES J & S
bad PSOM (Speedo)
O/LB to:
C202 F and M
Fuel Pump Module
Serves Component:
Instrument Cluster
C185 @ PCM to C202 F and M
Verify PCM & MLPS wiring & Pin numbers using following WIRING DIAGRAM by Ford
I messed up this reply due to my lousy tablet and the pop up ads here.
Bmarlowe30
Bmarlowe30
Midland, Tx.
Supreme
  Thanks for the reply. I have read your posts for months and tried everything before posting about it.. if anyone knows I think it wopuld be you.
Now the picture you linked looks to be the computer plug? if so how do you jumper it and still plug it in so it will run.
my abs plug looks nothing like that I have attached pictures of mine.
you have no idea how much I appreciate your input
  Brian
The jumpered connector is from the ABS module underneath the coolant recovery tank/ws washer tank.
Just jumper the pins shown.
jumper 14 to 21,
39 to 22
You will see The amber ABS light, but hopefully your psomwillmwork and e4od shiftt
Bmarlowe30
Bmarlowe30
Midland, Tx.
that is a picture of the abs module under the tank. it does not have a plug like the on in your picture that I can see.
could it be that module is bad causing all of this?
also what color wires control the speedometer on the inside of the cab?
Bmarlowe30
Bmarlowe30
Midland, Tx.
Everything I looked up does not show my93' has an abs module
only shows to have one on the 5.8 but not with the 5.0
Sorry for delays. I am often on in mornings around 0900 hours EDST to early evening hours. It depends on physical therapy home visits. At night, I may appear to be logged in, but that is because I often try to log out, but error messages pop up, so I shut my Tablet down.
Now I can see both of your pics. The pop-up ads here blocked out the 2nd pic yesterday, both pics are of the 4WABS Hydraulic Control Unit (HCU) aka pump, on driver's side.
Here is the 4WABS Control Module PN Label F37A-2C018-BB & 40-pin connector pic in a 93 Bronco. "...NOT for 94-96 Bronco; 94-96 Broncos were built with a different PN module.
by Steve
Compare this pic to your two pics;
4WABS Hydraulic Control Unit (HCU) pic on right side & Control Module with 40-pin connector on left side in 93-96
4wabshcu.jpg by Steve
4WABS Hydraulic Control Unit (HCU) Description, Location Removal & Installation; "...located outside of the engine compartment on a bracket which attaches to the left frame rail. It consists of the following: Brake pressure control valve block assembly, Pump motor, Hydraulic control unit reservoir w/ a fluid level indicator assembly. Disconnect the battery ground cable. 2.Unplug the 8-pin connector from the unit, and the 4-pin connector from the pump motor. 3.Disconnect the 5 inlet and outlet tubes from the unit. Immediately plug the ports. 4.Remove the 3 unit attaching nuts and lift out the unit. 5.Installation is the reverse of removal. Tighten the mounting nuts to 12-18 ft. lbs. (16-24 Nm) and the tube fittings to 10-18 ft. lbs. (13-24 Nm. After reconnecting the battery, it may take 10 miles or more of driving for the Powertrain Control Module to relearn its driveability codes. 6.Bleed the brakes..." by Ford
Do you think a previous owner or shop removed the Control Module?
Look for its 40 pin connector below the washer fluid tank.
Will post this now, then look at your two pics again to view in larger size.
EDIT, your 2 pics are of the 4WABS Hydraulic Control Unit (HCU), aka pump.
Is amber ABS light on with engine running ON?
Bmarlowe30
Bmarlowe30
Midland, Tx.
no abs light on. no check engine light.
I have a 12 pin plug with nothing plugged into it.
have not found the control module so may have been removed
Bmarlowe30
Bmarlowe30
Midland, Tx.
just looked under and I have no plug or module like that
also I checked the engine wiring harness I took off and neither it nor the new one have that plug on it
also I have the abs plus going int my front wheel hubs and the plug coming out but they have nothing to plug into
Yo Brian,
Well, previous owner or shop hacked the life out of it. So since you do see the HCU it confirms it did have the 4wabs and a control module, plus front wheel sensors, agree?
Next step is to obtain the needed harness and control module, install and to jump out the module pins.
Will post because I see that you are logged in.
Will find a harness diagram Depiction for you.
This from 96 Bronco-F-Series Workshop Manual (PARTIAL) by FORD via
Same as most earlier years especially 92-96, except for: OBD II in 96; 4WABS (93-96); RABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.); R134a in 94-96;
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD;
and a few other items that I still need to research such as Mass Air Flow in 95 5.8 California models and in all 96s, other years used Manifold Absolute Pressure Sensor (MAP).
Wiring Harnesses
http://www.diesel-dave.com/vehic/manual/stj/stji1015.htm
See:
Fender Apron, Left, Gasoline Engines
Item Part Number Description
1 33777 Nut
2 16E555 Insulator (Bronco Only)
3 — Locator, Position in Hole Provided (Part of 12A581)
4 — To LH Parking Lights
5 — To LH Air Bag Sensor
6 — To LH Headlamp
7 — To LH Turn and Park
8 12A581 Wiring Assembly
9 — To Canadian Daytime Running Lamp
10 N806972-S36MG ***** to Ground Wire Assembly
11 — To Windshield Washer Pump
***12 2C279 Anti-Lock Brake System Control Module Bracket and Assembly (40 Way) (Bronco Only)
***13 — To Anti-Lock Brake System Control Module
***14 — To Hydraulic Unit (8-Way) (Bronco Only)
***15 — To Pump Motor (4-Way) (Bronco Only)
16 N806327-S190 *****
17 14B005 Sensor and Bracket Assembly
18 8496 Radiator Support
19 — To Intake Air Temperature Sensor
20 9A603 Air Cleaner
21 — To Mass Airflow Sensor
A — Tighten to 9-13 Nm (80-115 Lb-In)
B — Tighten to 5-7 Nm (44-62 Lb-In)
C — Tighten to 10-14 Nm (7-10 Lb-Ft)
Bmarlowe30
Bmarlowe30
Midland, Tx.
I have two wiring harnesses and neither have it.  any idea where I can get a new one that is right?
I think you need to come over and fix this lol I am so dang frustrated
Yo Brian,
I doubt that there any new harnesses around. Give local Ford dealership parts dept.s a call. Would be $$$.
Probably use a yard queen's harness and module. But ensure they guarantee it withn $ back.
http://www.hollanderparts.com/
A yard that uses Hollander Interchange can search other yards and have it shipped to local yard.
Can select certain parts
Has Vehicle Pics! They show about 3 - 5 pics for some vehicles
I selected: 1993 Ford Bronco Electrical Engine Wire Harness Alternate Engine Wire Harness, does not show the module harness.
1993 Ford Bronco Brakes Anti Lock Brake Parts 01228 AssemblY
But has this note, "*All parts shown will fit the searched vehicle, even if they are different years, makes, and/or models." That would not be good for selecting the module.
Has engine bay pics. Looked at only two, but ws washer / coolant recovery tank is in the way, would have to be a pic from overhead to see a piece of the harness or the module.
or
http://www.copartfinder.com/finder/searchMake.do
Has Vehicle Pics! They show about 4 - 5 pics per vehicle incl. interior/dash, back seat, front & rear and engine bay.
Can NOT Select certain parts
Typical pic is http://images.copart.com/website/data/pix/20151113/37351935_07X.JPG
http://www.car-parts.com/
Has Some Vehicle Pics! They show about 4 - 8 pics per vehicle incl. interior/dash, back seat, front & rear and engine bay.
I searched for:
1993 Engine Harness Wiring Ford Bronco Full Size
Each Bronco shown has one engine bay pic, such as this;
https://wsimgproky.car-part.com/2970/2016/160140/2970_31074_07_web.jpg
As you can see ws washer / coolant recovery tank is in the way, would have to be a pic from overhead to see a piece of the harness or the module.
http://www.picknpull.com
This is a Company name w/yard locations in various states
http://row52.com/Search
Has Vehicle Pics AND Want a Part? It's Easy...
1. You create a Parts Wanted Listing.
2. Parts Pullers respond with offers.
3. You pick the best one.
A Parts Puller gets the parts you need.
for obsolete parts by Ford long version pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
Hey, I would help,there, but I am not mobile now. Learning to walk again, but look me up in 2017.
Thanks for the prayers!
You wrote, "I have two wiring harnesses and neither have it."
Did these come out of a F or E series? If so, they did not have 4wabs until around 97.
Was thinking last night that other harnesses &/or connector and maybe components were hacked or removed. Can you make a list of the sensor's that you are sure are in place and are hooked up, aside from TPS & VSS?
Engine Coolant Temperature (ECT) Sensor
http://www.supermotors.net/getfile/782138/fullsize/what-is-this-2.jpg
http://www.fullsizebronco.com/forum/attachment.php?attachmentid=56082&stc=1&d=1420553019
ECT Sensor Location in a 96, same for your 93;
1 ECT Sensor Location (Part of 9424)
2 9F593 Fuel Injector
3 9C968 Fuel Pressure Regulator
4 9D280 Fuel Injection Supply Manifold
5 9D930 Fuel Charging Wiring
6 — Fuel Return Tube (Part of 9F792 Assembly)
7 — IAT Sensor Location (5.8L, 49 States Only)
(Part of 9424)
8 — Water Temperature Sender Location (Part of 9424) this is for temp gauge.
9 — Pressure Relief Valve
(Part of 9F792)
Idle Air Control (IAC)
Intake Air Temp (IAT); (Air Charge Temperature [ACT] prior to 1992), is in the air cleaner tube on SFI engines.
IAT will have a connector with 2 wires. looks like it plugs right into the intake
Manifold Absolute Pressure (MAP); used only in Speed Density Systems https://www.supermotors.net/getfile/859755/fullsize/map-bap-location.jpg
Canister Purge Solenoid (CANP)
Passenger side, near throttle body
EVP Sensor
Atop EGR valve
Manual Lever Position/Transmission Range (MLP/TR) Sensor
Driver side of E4OD
EGR Vacuum Regulator (EVR), TAB, TAD location pic
http://www.supermotors.net/getfile/848247/fullsize/tab-tad-evr-coil2a.jpg
Thermactor Air Bypass Solenoid (TAB, AIRB, AM1) w& Air Bypass Valve (AIR BPV) & Thermactor Air Diverter Solenoid (TAD, AIRD, AM2)
TAD (Diverter) Valve located at the rear of the Intake Manifold on Crossover (aka "Y") tubing at
You have to climb up onto the engine to feel the Diverter Valve or remove the Intake Manifold. I'd rather climb up using plans, ala a scaffolding type set-up; maybe remove hood depending on circumstances such as me now, w/ backache..." by SeattleFSB
VRESER is the Vacuum Reservoir Can
Bmarlowe30
Bmarlowe30
Midland, Tx.
ok
1.IAC does not have plug or spot for it
everything else you listed I have and is plugged in.
also have replaced the 4WABS control Module and the MLP or Neutral Safety Switch
one other thing. my overdrive light does not work. I took it apart and repaired the wires and put it back together but still does not work. not sure if that matters just throwing everything out there.
I'm at the point of giving up honestly
Hang in there. You found the 4WABS control Module? Did you find the harness connector that needs to be jumped?
IAC Location pics in a 93 by Bobby
Alarm... well, that needs to yanked and wiring needs to checked. Can you make out name, part number?
This is stock module,
antitheft-module-003.jpg pic by Mikey350
figjeti
