1992 ford bronco schematic for where transmission lines go on E4OD
rogmit
 Does anyone have a schematic for where the transmission lines go from the radiator to transmission cooler and to transmission.Like a *******, I should of taken pictures 3 1/2 months ago when I removed lines because I was putting in new transmission and lines and now I don't remember where they go.I thought one of my manuals would show but they don't. HELP!
yo Rm
See if this will help;
93 Bronco-Econoline-F-Series Workshop Manual by FORD
https://www.motorcraftservice.com/pubs/content/~WSPM/~MUS~LEN/21/SPMLEFT.HTM
see
https://www.motorcraftservice.com/pubs/content/~WSPM/~MUS~LEN/21/SPM71A26.HTM
Section 07-01A: Transmission, Automatic, E4OD
1993 Bronco/Econoline/F-Series Workshop Manual
IN-VEHICLE SERVICE
Transmission Cooler Line RoutingRefer to the following illustrations for transmission cooler line routing.
Transmission Cooler Lines, F-Series and Bronco (Except 4.9L Engine)
CAUTION: Whenever a transmission has been disassembled to replace worn or damaged parts or because the valve body sticks from foreign material, the converter and oil cooler MUST be cleaned by using the Rotunda Torque Converter/Oil Cooler Cleaner 014-00028 or equivalent. Under NO circumstances should an attempt be made to clean converters by hand agitation with solvent.
Coastersfwb
