1989 Rear Axle Swap
a11drewp
what rear ends will bolt in if any to my 89 xlt? any help is appreciated!!!
Early 80,s ford nine inch , 80 to 96 ford 8.8 outta half ton trucks and broncos , 80 to 96 dana 60 and 10.25 3/4 ton rear ends . And pretty much anything you want if you have a welder and a set of $15 spring perches from jegs :D /emoticons/[email protected] 2x" width="20" height="20" />
A
a11drewp
a 1987 ford 1ton rear axle should be a dana 60 right...... will that bolt in... maybe have to weld in spring perches?... what about u joints.. will i have to swap yokes or what? thanks for your help!
david@holycitytransportat
