1988 bronco hubs problem
06f350
I got a 1988 bronco went to buy warn hubs. Cannot use premium hubs then they said standard will not fit 1988 or 87 models. Any suggestions? please help
oktogo
york sc
i herd that there is an adapter 4 them try finding one of them that might help
yo!
They are correct, sorry to say.
87-88 Bronco Hubs are different than other Broncos; "...This was another of Ford's better ideas. For '87 and '88 Ford used a one-piece locking hub assembly. This hub simply sits between the wheel and brake rotor and is held in place by the wheel studs. This type of hub is very easy to remove (simply remove the wheel), but it is different from all other Broncos and therefore parts and replacement hubs are expensive and hard to find. To convert your 87-88 Bronco to the "standard" hubs you'll need to swap all the parts from the spindle out from a Bronco or F-150. It may even be possible to take these parts from any vehicle with a Dana 44 front axle and the same wheel bolt pattern as the Bronco (5 on 5.5"). If you are considering this swap it would be a good time to consider the 8 lug axle swap you've always wanted (see section 10.2)..."
Source: by Matt K at off-road.com via web.archive.org
jsomedaysoon
outer banks nc
what exactly is wrong with your current hubs? i've found that junk yards are an exellent option for that particular model hub. the yard i go to has dozens of bronco's with that set up.
