Consider a non-stock muffler instead of the straight pipe; if you go w/pipe; get aluminized or ss pipe and ss clamps otherwise reg steel pipe will rust out clickly as stock ****** mufflers do.
I have some Sound Clip Links in my site @
http://schwimserver5.com/index.php?index=574
This is by Walker who made and still makes the original/replacement Bronco exhausts (as well as for almost all US Fords for many years) diagram for your year.
Consider Walker® SoundFX® Muffler 18357
100% aluminized material
Reinforced bracketed heads
Mechanical interior joints
Spun-locked heads
or the turbo, glasspack, etc.
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Click your name in right black panel in upper right;
In pop up,
Click, My Profile
Click, Edit My Profile in right side black panel
In left panel, Click, Edit Signature
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
http://www.irfanview.com is a good free image resizer. I
Post any TECH questions in a new thread in 80-96 Ford Bronco Tech Support section & keep it limited to one issue. Mainly so that old farts such as I don't get confused.
To show off your Bronco, such as any build-up or modifications post, in 80-96 Ford Bronco section.
Here are some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) @
http://www.revbase.com/BBBMotor/Wd Just register for free.
Our sponsor, Jeff at the Bronco Graveyard has offered a 2% or 3% discount (in process of determining which) to members of The BroncoZone for
on line orders.
To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
