Lift?
brad050
Ok so if I put a 4" lift on a 95 bronco what other parts will I have to change?
Also any one know a good place to get a good cheap 4" lift?
ms_jetset
Redneck & The Bronco
The Big Apple:-( N.E. Pa on wkends:-)
'brad050',
Yes it is ok. I own a 95 Bronco, and put on a 4" lift kit. There are going to be a few ajustments to make. It also depends on what size tires your going to run.
I got a fairly resonablly priced lift from Superlift. And I put 33"s on as well. So I needed to make a new brake line as well as cutting some of the front fender out.
Hope this helps you!
ms_jetset
brad050
'brad050',
ms_jetset
You needed to cut the front fender with a 4" lift and 33's?
brad050, check with our sponsor, Jeff's Bronco Graveyard, for the 4" Superlift kit. You can re-locate the front brake lines, but many folks opt for replacing with longer or extended stainless steel DOT-approved lines for the lift. The driveshaafts usually don't need to be extended. You will need a frontend alignment afterwards. I've also found over the years that a 4" kit will sometimes give you a bit less or a bit more in actual ride height, depending on what parts are replaced and the condition of the vehicle suspension. Even amongst the same brand, you may or may not have tire clearance issues. Most of that will depend on the brand of tire and wheel size you mount them on. JSM84
kyleh01
