spark issues
C
chet.rowell
south dakota
i cant figure out why it wont start it was starting just fine then i did some work on the throttle body and now it wont i checked the fuel rail and it is just fine it turns over but acts like it is getting no spark
Chet,
I have been away, but will certainly check back in this weekend. IF you are still with us, let us know with some kind of a reply.
IF you have no spark, starter fluid will not help. SO we need to track down why you have no spark. This can be a complicated issue.
C
chet.rowell
south dakota
ya im still with ya . im still working on the issues its really complitcated cause i have no schematics to go off of so ya. but working on it
Hi Chet,
You indicated that you have a high idle and no spark. That can not be the case.
So let's go with no spark, and therefore will not start.
When you check for spark, you can do so at the plug, and from the coil to the cap.
I'll assume that you have no spark in either place.
Make sure you have 12 volts at the bat side (+) side of the coil with the ignition key on.
Also check the coil itself.
Primary resistance should be 0.8 - 1.6 ohms
Secondary should be 7.7K to 10.5K ohms
The primary resistance is measureed between the two small terminals.
The secondary is measured between the Large terminal (that connects to the coil wire to the cap) and the (-) negative (tach).
If the coil is out of specs, replace it.
You may also pull your ignition control module and have it checekd at an auto parts store.
Let us know how you make out, we'll go from there.
C
chet.rowell
south dakota
does any one got the schematics on the spark and ignition route so i can find where im not getting spark
What year truck do you have? Add your truck vitals to your signature file, it helps get better answers.
This one is good for 80 - 86 Duraspark II systems
C
chet.rowell
south dakota
i am updating from my previous my truck turns over. it has spark but will not fire. i check the fuel rail and there is pressure so i know the fuel is getting there but why wont it fire all the way . it sound like its not even trying to fire. any advice there peeps
i apriciate all the help i can get
How much pressure? What does the spark look like, what color is it? How far will the arc jump? Have you tried removing the SPOUT jumper? That removes the computer control from the equation. Getting any codes?
Keep your posts on the same topic in the original thread. I am going to merge them.
I was just reviewing your posts. I noticed that you have posted about putting a performance chip in. Have you tried putting back the original chip?
C
chet.rowell
south dakota
alright the spark is blue and the whole spark plug lights up. i was wondering if there is a **** switch or something along them lines and if there is one where would it be located
C
chet.rowell
south dakota
okay here is all the info i have i just bought the truck and it had some high idle problems so i took the throtle body apart and the gasket was bad. so i replaced and put it back together. that is when the problem accord first i thought it was a spark prob but the i tested it and found the spark plugs are sparking. then i tested the fuel rail and it has pressure. but why wont it turn all the way over. the spark is blue and the whole spark plug lights up. now is there a **** switch on the truck and if so where is it located and
C
chet.rowell
south dakota
i have a 93 ford bronc0 and i check the spark plugs they are sparking . the spark is blue they are spark the way they are supposed to. then i check the fuel rail and it looks like it has enough pressure. but still wont fire all the way. can anyone help me
DO NOT open a new topic on one you previously have opened. Did you put the original chip back in that you replaced with a performance chip? As far as pressure at the rail, what was the pressure reading?
I am going to merge this post with your other posts on this topic.
Chet,
Please read the questions put to you and do your best to answer them.
When you make a statement such as... I got spark, please discribe for us, HOW you came to that determination.
Seabronc mentioned pulling codes, and pulling the SPOUT, you made no comment about those suggestions. If you don't know what he meant, then please ask for clairification, we are here and willing to help.
Please read your post, after you write it, and before you post it, to see if you think it would make sense to someone else, or if there is a way that you can make it more clear.
C
chet.rowell
south dakota
i pulled the spark plug out and i hooked it up to the spark plug wire and had some one else start the truck that is how i found i was getting spark i am going to try the spout idea here in a sec. i can pull codes can find a obd 1 code reader anywhere here in town no one in this town is equiped with one they all have obd2 scanners
