A/C
Seth
Does anyone know if you have to have an orifice tube (otherwise known as an expansion valve) for you to have A/C?
I've had a few people tell me I do and do not but the most popular response was, "What's an orifice tube?"
Also if needed I have an '83 Bronco XLT
You should have it
Here is it's location diagram by Chilton via AZ
1980-86 See Figure 3
AZ didn't load your year range for the O tube,so here is their overview of it in 87+
http://www.autozone.com/servlet/UiBroker?F...23d800a3703.jsp
Expansion Valve/Orifice Tube For vehicle: 1983 FORD BRONCO V8 5.0 Liter 2BBL (change)
10 parts found.
Part No.
38621 Factory Air Expansion Valve / Orifice Tube
Orifice Tube; Factory Air; OE Replacement; Single Tube $2.99
Some sources other than Ford, NAPA,
Advance Auto
http://autoparts.cardomain.com/auto-part/1...-c-orifice-tube
http://parts.leftlanenews.com/auto-part/10...-c-orifice-tube
S
Seth
yo,You should have it
10 parts found.
Part No.
Advance Auto
When I was first dealing with this question I noticed that the previous owner has bent the inlet tube to the evaporator core causing a bend inside the tube along with the O-tube itself. I managed to bend the inlet tube back to it rightful possession. After I remove the O-tube and there's still a bend (looks as it theres a tube within the tube where the O-tube goes in) will I need to replace my core or can I straighten this out?
yo
That Location Link takes you to the main vehicle/year/model etc selection page; AZ has changed some URL's so here is the one that takes you to the Location of the O tube directly;
http://www.autozone.com/az/cds/en_us/09008...irInfoPages.htm
Doubt that the tube can be straightened out well enuf..
here is a comment by a major AC repair firm to sim Question;
"I'm running an original Evaporator, which means the
high line with the orifice tube in it is slightly
bent. This naturally makes the orifice tube bend
slightly as well. Does this bending of the orifice
tube affect performance of the AC at all? Things a
bugger to get in there without breaking?"
ANS:
That is the biggest problem in the AC system. Good luck on getting the old one out and the replacement in. I have my theory as to why it's this way but the new evaporators we make eliminated the problem. Sorry I can solve the problem your having now.
John Hervey
www.specialtauto.com
BUT!
www.4s.com offers a tube repair kit!!!!!!!!!!
16155 Part Information
Evaporator Core Repair Kit w/o Orifice Tube Repair Kit; w/ Spring Lock; w/o Tube
e mail them to confirm; get a n O tube as well
figjeti
