fuel pump?
bko4x4er
i have a question. see my truck will start fine either after it has just been turned off then started right uop again or after it has been sitting for a while. but if i try to start it in bettween when it is still warm, it hesitates and takes a few seconds to crank up. do you think it might be the ful pump? it has 254,000 miles i doubt its ever been changed.
i have a question. see my truck will start fine either after it has just been turned off then started right uop again or after it has been sitting for a while. but if i try to start it in bettween when it is still warm, it hesitates and takes a few seconds to crank up. ? it has 254,000 miles i doubt its ever been changed.
nope
could you please explain this differently, or more fully?
thanks
joe
bko4x4er
bko4x4er
do you think it might be the ful pumpnope
thanks
joe
well it will turn over and over and not start but if you keep cranking it , it will finally start.
Does your check engine light come on?
Try this. Turn your key on, count to three, and then try to start it. Let us know if that helps.
bko4x4er
bko4x4er
yes i do wait for the fuel pump to click. i dont just try to hurry up and start it. and yes the check engine light comes on but only for a second then it turns off. but then comes back on when i get a mile down the road.
Leadsled
Bullhead City AZ(right on the river!!)
Well if the check engine light is coming on when it is running have you ever thought about pulling codes???????
bko4x4er
Here is a short tutorial I wrote that will teach you how to pull codes.
The tutorial starts at post #4
All you need is a little 4 inch piece of wire and the ability to count to ten.
http://broncozone.com/forums/index.php?s=&...ost&p=74581
The only problem with pulling codes and then fixing your truck is that you will probably loose the ability to brag about only getting 6-7 MPG.
bko4x4er
bko4x4er
bko4x4erHere is a short tutorial I wrote that will teach you how to pull codes.
so i read that. how do you know what codes are what?
is there a list of codes. .......say 35? what it mean...see i dont know that. is there a link or a liost i can use.
bko4x4er
bko4x4er
so i read that. how do you know what codes are what?is there a list of codes. .......say 35? what it mean...see i dont know that. is there a link or a liost i can use.
WHERE COULD I GET A LIST OF WHAT CODES MEANS WHAT
Can you open an adobe acrobat pdf file?
If so, within the codes page you read in post number 12 there is a link to a manual for the actron code reader. There are many pages of codes in there.
http://broncozone.com/forums/index.php?act...ost&id=6792
Sometimes the discriptions of the meanings of the codes are a little different from one source or another.
Another source is www.fordfuelinjection.com
Yet another is miesk5's page
http://www.broncolinks.com/index.php?index=23
The first step is to get your codes.
Second would be to look them up at one or more of the sources listed above, and third let us know what you discovered, especially if the answer is not clear.
good luck
joe
