95 bronco 302 running ruff
aquaholic33
I have a 95 bronco. the truck runs good except on cold starts. with my remote starter or if in the truck when i go to start it at a cold start it always stalls. Even in warmer weather same thing. when it does start after the second try it get a idle flux then evens off after 5-10 seconds. I think it might be a bad egr. also at very low throttle i get some hesatation
Any idea's????????????????????????????
I have a 95 bronco. the truck runs good except on cold starts. with my remote starter or if in the truck when i go to start it at a cold start it always stalls. Even in warmer weather same thing. when it does start after the second try it get a idle flux then evens off after 5-10 seconds. I think it might be a bad egr. also at very low throttle i get some hesatationAny idea's????????????????????????????
Try a Self Test for Codes;
Self Test - & Connector Location & pics, Bronco & Ford BEST PROCESS WITH DIAGRAMS! Source: by Ryan M (Fireguy50) at fordfuelinjection.com
and;
Self Test - A technician that is unfamiliar with the EEC Self-Test can mistakenly believe that continuous Memory codes are not present when they really are. He may run KOER Self-Test and get a pass code (111) and not realize that KOEO Self-Test must be run to receive any Continuous Memory codes. He may run KOEO Self-Test while counting MIL flashes and misinterpret the repeated hard fault pass code (111) to mean that Continuous Memory does not contain any codes. The engine temperature must be greater than 50
eholt80
