So now I am thinking... I'll just wait for the darn thing to get worse until it isn't an intermittent problem any more.
joe
So guess what? It's worse.
OK.. so I hooked up my fuel pressure guage, and found that the pressure remained pretty constant, and always within range even when the engine stalled. Lucky me... I just saved myself $200. BTW... thanks BroncoBill for the URLs for less expensive guages.
Next I got out a spray bottle, filled it with water as spritzed the wires. that didn't make anything any worse, so I turned it to stream, and downright got them good and wet. Nope... it looks like the wires are in good shape. Yes SeaBronc, I had replaced the cap and rotor.
SO I tested the primary winding of the coil, but wasn't sure if I tested the secondary windings properly.
I tried to check the air cleaner, but two of the four screws were spinning but not coming out. I quit just before going to get my sawzall. That'll be a task for another day.
I also tried to pull my PVC valve, but it is really hard to get to, and I was afraid that if I got it out, I may not be able to get it back in, so I skipped that too.
At this point I started considering just buying new parts and putting them in, or taking it to a local mechanic who is supposed to be pretty good, or taking it right to FORD. Then it struck me... NOW that it is bad enough.. maybe it will throw some diagnostic codes!?
So I got out the book and read about how to test for codes without any special equipment. I tried it, and son of a gun... it worked!
I gotta tell you, that was pretty damn exciting. The last time I worked on cars was in the '70s, and that was on cars built in the 60s (points, condensers, and carburetors). A year ago, I thought I would replace the plugs on my Crown Vic, and couldn't find them. I started to remove this long tube to get it out of the way, and son of a gun... gas came out of it!
OK, so I got a code 22 which means my MAP sensor is out of range.
So, do I just replace the MAP sensor? Or is it more likely that it is working, and is reporting another problem that needs to be fixed?
BTW BroncoBill, I am sure that Shatner would love to have your nickname. He would mount any alien, whether she was green, or was a thousand years old.
Again thanks guys,
joe
