CLICK TOP RIGHT VALVE AREA
barrett86
Spokane, Washington
HEY GUYS, back with my bronco with yet another problem, i was leaving the junk yard and i was speeding up to catch up with traffic on busy road and when i came off the accelerator i have a loud click the goes with engine speed. a buddy told me it could be one of the rocker arm/ roller rockers . he had me use a long screwdriver as a stethescope and i could hear clicking through the handle, but i want to know what you guys think. its on my passanger side, so do i have to remove the plenum to remove the passanger valve cover or am i ok. please let me know.
Other than the click does the engine run OK, or is it a little rough? Since you have an 86 you probably don't have roller rockers.
If it is a little rough running you may have a broken valve spring, no big deal to fix. Unfortunately, I believe you will have to take the plenum out of the way to remove the valve cover. Then you can use a bump switch to turn the engine over while observing the valves. You might want to do a quick compression check first. If a spring is broken, you can change it without removing the heads, I'll go over the procedure if that turns out to be the case.
No loss of power, or rough ride, he thinks one of valves is loose.
If the engine were running rough then I would say a spring, but since it runs smoothly then he is probably right. Unfortunately you will still have to remove the plenum to get at the passenger side cover off :angry: , unless someone here knows of a way to do it without removing the plenum :) /emoticons/[email protected] 2x" width="20" height="20" /> .
barrett86
Spokane, Washington
Ok got valve cover off nothing looks out of order all the rockers are tight, i guess ill put er back together and hope for the best, and i think my oil is LOWWWW.
Am I the only one here who thinks this sounds like a lifter ? Valves, rockers & springs are probably just fine. Just got you a stuck lifter (that's what I'd think off the top of my head anyways)
barrett86
Spokane, Washington
well to put all minds at ease lol it was loose bolts on my exhaust manifold. HHAHAHAHAHHAHAHAH. LUCKY ME. yep shes quiet now, until i give it gas then it sounds like a tornado coming thru, anybody else with a 302 notice how loud it gets when you stomp the gas.
