is there a difference in driveshafts 78-79
BrianMac
Is there a difference in driveshafts 78-79 if there is can I make it work
there IS a differencethe 79 has the double cardon shaft
No, there isn't. BOTH the 78' & the 79' have the double cardan shafts, please see the pages I scanned from the *1978* factory manual. Just what kind of driveshaft do you think a 78' has ? 1978 E100-E350, F100-F350 & P600 trucks were sometimes equiped with a single snap ring type Ujoint, depending on wether it was a long or shortbed truck but the *only* driveshaft offered with 78' & 79' Broncos was the double cardan and that's because of the short wheelbase, the longer wheelbase pickups could use the single snap ring but NOT the Broncos. I'll scan the pages if you need to see them.
http://broncozone.com/forums/index.php?showtopic=12560
Broncoholic
Broncoholic
Mankato MN
ok ok I was wrong about the cardon part but, they are different the yokes on the 79's and some very late 78's are larger
Yup, you're dead on. Those freaking yokes are all over the place for some strange reason. Blew out a rear shaft once in one of my 78/79's at 5pm just a half mile onto the TappenZee bridge in NY coming home from Dive School in Jersey. Drove it home the rest of the way on the front end with bearings that would grind like you wouldn't believe every 20-30 min after they heated up. 10hr drive that I'll *never* forget, scrambled to fix it that wkend and had to fedEx in the yoke because I couldn't find a match after checking at least 40 trucks at 3 junkyards. $65 for the yoke, $90 for FedEx. I wanted to throttle whoever was responsible for THAT production line decision. The driveshaft that *I* had ran the next size larger U-joint which under any normal set of circumstances I would have been thrilled with and in the end it didn't even MATTER because I'd screwed up the shaft so badly when I threw it that I had to have a whole new one fabbed so I could have used ANY of the damn yokes I'd seen. Talk about throwing wrenches around. By the time I was done fixing the yoke & the shaft it was a $600 wkend, not only THAT but the whole reason I'd come home was to see my girl & she was so mad I was working on the truck that she wouldn't even see me. THAT sort of $hit will give you a stroke.
