Brakes
markinark
Arkansas
Does anyone know where to get a brake porportining valve? You know the valve that sits on the left side of the frame under the body that divides the braking between front and back. Mine seems to not be working properly most all my braking is coming from the rear. Is there a way to fix the one I have?
You may be able to rebuild the valve if you can find a rebuild kit (a collection of new seals) but you should also be able to get a rebuilt valve pretty cheap from your local Napa, autozone , etc or from a mailorder house like Jegs or Summit.
Titos79
LMC Trucks (lmctruck.com) lists one PN 45-4005 that lists for 229.95 last time i checked and that is plus shipping and the pressure switch pn 47-0904 (27.95). this is tho only one i have been able to find. but for that price i'd probably get the one from summit and then rig the wiring to turn off the brake light. i dont think they have provisions for the pressure switch.
