tire guide
pntbllrules53
West Haven, CT
im looking for new tires, i look in every magazine and website i get my hands on. i keep seeing something like 31x10.50R15LT i kinda understand what it means - 31in high 10.50in wide and 15in rims ... i get confused with the ones like LT235/85R16 what does that translate into????
Roadkill
Killeen, TX
LT=Light Truck
235=width (in milimeters)
85=% of width that sidewall is tall
R=Radial
16=rim diameter in inches
The % thing sounds wierd so here is what it means:
235mm X .85 = 199.75mm
sidewall is 199.75mm high
Once you convert milimeters to inches, a LT235/85R16 would be roughly a 32x9.25 tire for a 16 inch rim
Edit:
I left out that sidewall height should be multiplied by two before adding to rim size to get overall height.
rubberdust
Henderson NV
section width (235) in mm divide by 25.4 = inches
section width multiply by aspect ratio in this case .85 = section height
section height mutiplied by 2 plus rim diameter (16) = OD or tire height
or something that is close to a 32X9.50R16
Roadkill
Killeen, TX
section width (235) in mm divide by 25.4 = inchessection width multiply by aspect ratio in this case .85 = section height
Good catch on my math error, Rubberdust. I should have noticed something amiss when I came up with only a 24" tire.
Coastersfwb
