Deploying very soon need help with a4ld
ARMY INFANTRY
I have an 88 Bronco II Eddie Bower edition 4x2 and the trany is shoot I found one from a 4x4 bronco A4ld but now It won't shift and The pig tail on the left hand side won't fit. It won't shift what so ever only when I drop it in to 1 or 2 and it shifts into gear very hard new Fluid and filter and im running out time im deploying in 27 days
Roadkill
Killeen, TX
Hey Infanty,
You'll be more likely to get an answer to your question in the Bronco II forum which is just below this one on the main forums page. By the way, Welcome to Broncozone > ! I'm sure someone here has an answer to your question but unfortunately I do not.
Good luck, and stay safe.
yo!
eziest and cheapest cks first for you;
Modulator - is #1 problem
You have a modulator on the passenger's side of the vehicle pointing towards the driver's door. Pull the rubber line off the modulator and see it trans fluid comes out of the line, if it does your modulator is no good. It can cause any of the above symptoms. If good, check vacuum line from engine to mod valve; or kinked/cut vacuum line to modulator; Check vacuum at modulator - should be 18 - 20 "
Check the kickdown cable; it is self-adjusting over a tolerance range of 1 in. (25mm). If the cable requires readjustment, reset the by depressing the semi-circular metal tab on the self-adjuster mechanism and pulling the cable forward (toward the front of the vehicle) to the "Zero'' position setting. The cable will then automatically readjust to the proper length when kicked down
& the 2 prong plug is for the torque converter's lock-up solenoid. In mid 88 the tranny had a second solenoid for 3rd to 4th inhibit; do you have a 2 prong on tranny or is it on the harness?
an early A4LD some had a mechanically locking torque converter, but later ones have an electronic one, however, this doesn't effect the normal running of the box if not connected; 3 - 4 shift and lock-up are commanded by the computer - these two solenoids can set codes - one wire is red, other is tan/light blue in 2.9 engine or yellow in 2.3
& converter clutch solenoid wires are Red; and white for 2.9 or org/yel for 2.3
Governor stuck or sticking is a very common problem. The governor is inside the tailshaft and requires removing the driveshaft and the tailshaft to access it (on a 4X2). 4X4 requires dropping the t-case as well. They do stick, but its usually from dirty fluid
"Look in the rear where the governor hub goes, and look for wear grooves in the case. If no wear is noted, use the rubber square cut seal rings for the governor. If wear is noted, stick with the steel rings. I usually take some fine emmory cloth and polish the bore to lessen the wear. Next area for inspection is the governor itself. Make sure the valves in the governor assembly move freely, they cannot stick even a little, unless you like torture. If they stick, clean them and polish the valves with fine polishing cloth.. " by TL!
Good Luck to you!
screemerk
4x4 and 4x2 tansmissions are not the same. Both are A4LD but output shafts are different. Trans would have to be disassembled to change shaft.
andre
gatineau hill quebec
1 did u use tranny and trafer case of 4x4 if yes ??
2 did u use 4x4 rear drive shaft
3 what year is you're donnor tranny
u can put 4x4 tranny on 2x4 as long u use same year tranny and need rear drive shaft
if manuel of auto shift 4x4 got to leave it in 2 wd on tranfer case also need to plug fr
output drive shaft
and as for the tranny not working in drive it the tranny is bad b cause i put one in f150
did work in drive just wont shift rigth commputer control new one
two selenoid old type 1 silenoid
best bet get it rebuilt there week those tranny get a use one that work 2 wd
good hunting
andre
output drive shaft
good hunting
Similar threads
T
Replies
Views
2K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
830
T
fred tyler
