I have a '93 Full Size Bronco and the ABS pump and manifold that is located on the frame adjacent to the left front tire leaks. The leak seems to be between the electric motor and pump assembly. I have spoken to several Ford dealers and the ABS assembly (what I call the pump) is no longer available.If it was it would be $1400!!! The brakes work fine other than having to add some fluid now and then. Has anyone had any experience with this part? Can it be rebuilt or have a seal replaced? One of my mechanic buddies suggested taking it out and connecting the lines direct. Any suggestions would be greatly appreciated. dburns.
