Hello,
Im kinda new here, and really need some new ideas. I have a 90 bronco, Its been sitting since 02. So i went to wroking on it, the fuel pump was frozen so i put a power lead from the battery and it started working. I pressure washed out the fuel tank, and got all the rust out of it. I have changed the spark plugs. and checked them 3 times. a new distributer cap and ignition coil. It had a fresh oil change and a fuel filter. And the timing is correct. The problem i am having is that when the truck gets warmed up it starts backfiring, and sputtering. does not bog down so the moter dies but it is close. I have checked the catalytic converter and it does not glow cherry red. I had a short in the wire to the distributer but i changed the wireing pig tail. I have about ran out of ideas, I had it checked on a computer, and the top oxygen sensor is reading bad, code 10 i think, and i have not changed it as of yet. does anyone have any idea what else might be wrong with my truck?
p.s - me and my friends are really stumped, and could use some help.
btw, thier is no check engine light on.
