oil leak and gas tank
nilzor
Hi,
my new 1990bronco loses lots of oil... its an 351 engine, Does anyone knows any typical causes? Or can it be everything? Another thing is, when i open the gas tank, i can hear air pressure coming out.
so i don`t have much expereine whit this cars.
maybe someone got some hint abot this car.
tanks
"---loses lots of oil---"
As in a qt. a day...? a qt. a week..??
OOPs, Just noticed "leak" in your title...
What I do is clean, (or have the eng. cleaned) top & bottom.
Once dry, it's easy to see where leaks are originating
mbtech2003
cape cod, mass
Hi,
tanks
air coming out of fuel tank ok
oil leak most lickly from oil pan or valve covers. do a search on this sight to find previous post where it is described in detail on how to replace
Air coming out of the tank is due to the evaporative emissions line being plugged. One of the purposes of the carbon canister located in the front of the truck is to allow the pressure in the tank to relieve itself. The pressure is caused by the tank heating up and expanding. On the other hand it also allows air into the tank to fill the space made by fuel being sucked out as you are charging down the road. I would fix the problem since it prevents the tank from colapsing or over pressurizing.
Oil loss can be anything, do you have oil leaking out of the valve covers, oil pan, smoke while the engine is running?
Coastersfwb
