6" lift
juGGernaut
for all of you that have have a 6" lift on your 78's & 79's, did you have to use aftermarket angel shims to correct your pinion angel on the rear? also, any one found out a way to get the bow out of the front coils with a 6 in. lift?
4xfan78
Georgia, augusta
I cut the angle in the blocks on one of mine. As far as the front I do not know. I believe that someone on this site hade something that mounted under the spring to correct this problem.
79fordguy
i have a 4" lift with no drop brackets and used 7* c bushings with wild horses degreed rear radus arm bushings and sierra bronco 7* shims under the coils to correct the bow. are you using drop brackets or longer arms with the 6" coil? what springs are you using? also do you have a adjustable trac bar and/or drop trac bracket?
Gryph
