MAXIMUM TIRE SIZE
luttrell, tn
what is the maximum tire size i can run on my stock 93 bronco with stock wheels / stock everything except exhaust... ??? i have ran 31 10.50 before but if i can stuff more tire underneath i would like to... thanks, steve
paul rondelli
Atlanta
You can get anything to work ... with a little help.
Here is my stock height 1993 Bronco with 35" BFG mud terrains crammed under her. The back is fine and I put about 200 miles on her with the 35" tires in the rear. The front is very tight ... and required trimming the front bumper ... and I still had a rub at full turn. It rubbed on the plastic splash guard.
The spring are stock ...... so they sagged at least a few inches. If you replace the springs and trim the bumper you should be able to stuff the 35" under her ... but I wouldn't try to beat on her too much. You just don't have the flex.
33" tires should fit all day long with a stock ride height.
pappy19
Garden Valley, Idaho
Has more to do with your rearend ratio as much as anything. With really big tires, a 4.56 ratio wouldn't be out of line.
paul rondelli
Atlanta
The 35" mud terrains actually belong on the Bronco with a 6 inch lift already installed.
I did re-gear to 4:56 and she takes off like a rocket .... but MPG took a big hit after the re-gear.
Bigger tires will also result in ball joint wear ... and steering gear wear.
bigd1948
