Spare tire carrier bolts.
SoFloBronco
Fort Lauderdale, FL
I want to freshen the spare tire carrier and I'd like to replace the mounting bolts with something less rust prone. Does anyone know the size/thread count on the mounting bolts and could SS replacements be used or is that not going to work?
Yo SoFloBronco,
Call local Ford Dealer Parts Department to confirm what a former member wrote "Those bolts have 10mm head, a relatively small captive washer, & 8mmx1.25mm threads about 30mm long with an angled slot in the tip for self-tapping. Common hardware bolts won't fit because the heads are too large. Hex cap screws probably will fit, but they won't look right."
ItemPart NumberDescription
11A401Locking Latch Bracket Reinforcement, Spare Wheel Carrier
21469Spare Wheel Carrier Support
3N606690-S55***** and Washer
41433Spare Wheel Carrier
5N803207-S100***** and Washer
61A429Spare Wheel Support
7388577-S150Pushpin
847104Spare Wheel Scuff Pad
957472-S2***** and Washer
ATighten to 16-27 Nm
(12-20 Lb-Ft)
BTighten to 8-15 Nm
(6-11 Lb-Ft)
DBStoots
Plantation, FL
Curious what you settled on?
Val
