1996
Prescott Bronco
Prescott Az
My 96 bronco 5.0 xlt Starts and runs fine, But when i put it into Drive the truck stalls out, it works when i put it into 1st and reverse, the light on the shift lever blinks but it was blinking when it would go into drive,, already did the trans pan removal to see if the trans filter was loose, it was not,, just want to get back on the road.. Any help? Thanks
Have you tried to pull codes? If the OD light is flashing that means there is an error code. Should help us narrow it down.
Well how recent are those codes? None are transmission related. They may affect it dieing in gear though.
171 and 174 is lean bank one and bank two. That is usually either you ran it out of fuel recently or a vacuum leak.
Could be other causes like fuel pump, fuel filter and other things, but start with the easy ones. Vac leak. Check for that first.
411 and 433 refer to oxygen sensors, could be related to the lean codes, but not as important. fix the lean codes first.
Yo Prescott,
As Tiha advised.
To avoid going through the following iests, "when vacuum leaks are indicated, search out and correct the condition. Excess air leaking into the system will upset the fuel mixture and cause conditions such as rough idle, missing on acceleration, or burned valves. If the leak exists in an accessory unit, such as the power brake, the unit will not function correctly. Or Air Conditioning when in MAX mode may switch to Defrost. Does it?
I guess your scan tool can't read Parameter Identifications (PIDs); they are codes used to request data from a vehicle, used as a diagnostic tool. Typically, an automotive technician will use PIDs with a scan tool connected to the vehicle's OBD-II connector.
The technician enters the PID, the scan tool sends it to the vehicle's controller–area network (CAN)-bus, VPW, PWM, ISO, KWP. (After 2008, CAN only)
A device on the bus recognizes the PID as one it is responsible for, and reports the value for that PID to the bus
The scan tool reads the response, and displays it to the technician...
1996 5.8L E/F-Series/Bronco (E40D)
Typical Diagnostic Reference Values
DPFEGR; EEC-V Pin #65/PID only;
Measured/PID Values
KOEO 0.2-1.3;
Hot Idle 0.2-1.3;
30 MPH 0.2-4.5;
55 MPH 0.2-4.5.
Units Measured/PID; DCV (DC Volts)
This is Fords pin-point test that a Ford dealer tech would do with Ford's old Break-Out Box; so, as I mentioned in another thread here, in place of the break-out box, go to the EECV connector pin instead; Substitute EECV connector pin Number for breakout box number.
EEC V Connector Pin Diagram
http://broncozone.com/uploads/monthly_07_2011/post-3816-0-58198100-1310643563.gif
Legend: IGNORE question mark symbol (?).
Pin Number; Circuit; Circuit Function.
1 315 (P/O) PCM to Transmission Shift Solenoid No. 2
2 658 (P/LG) PCM to Check Engine Indicator Lamp
3 Not Used
4 Not Used
5 Not Used
6 651 (BK/Y) Dedicated Ground
7 Not Used
8 Not Used
9 Not Used
10 Not Used
11 Not Used
12 Not Used
13 107 (P) PCM Flash EEPROM Power Supply
14 784 (LB/BK) 4x4 Low Range Switch to PCM Indicator Lamp
15 915 (PK/LB) J1850 Bus Negative/Data Negative (Return) to PCM
16 914 (T/O) J1850 Bus Positive/Data Positive
17 Not Used
18 Not Used
19 Not Used
20 Not Used
21 Not Used
22 Not Used
23 259 (O/R) Dedicated Ground to TFI Module
24 570 (BK/W) Dedicated Ground PCM
25 875 (BK/LB) Ground Logic Module
26 � Not Used
27 237 (O/Y) PCM to Transmission Shift Solenoid No. 1
28 � Not Used
29 224 (T/W) Transmission Overdrive Cancel Switch to PCM
30 � Not Used
31 � Not Used
32 � Not Used
33 676 (PK/O) Vehicle Speed Sensor � Negative (Return) to PCM
34 � Not Used
35 392 (P/LG) Heated Exhaust Gas Oxygen Sensor No. 3 to PCM
36 968 (T/LB) Mass Airflow Return
37 923 (O/BK) Transmission Oil Temperature to PCM
38 354 (LG/R) Engine Coolant Temperature Sensor to PCM
39 743 (GY) Air Charge Temperature Sensor to PCM
40 238 (DG/Y) Fuel Pump Monitor to PCM/Fuel Pump Relay to Safety Switch
41 198 (DG/O) A/C Pressure Switch to Control Relay
42 � Not Used
43 � Not Used
44 200 (BR) PCM to Air Management No. 2 (Was TAD)
45 � Not Used
46 � Not Used
47 360 (BR/PK) PCM to Electronic Vacuum Regulator � Constant Current
48 382 (Y/BK) PCM to Test Connector No. 2
49 395 (GY/O) Profile Ignition Pickup to PCM
50 929 (PK) PCM to Spark Angle Pulse Width/Spark Output
51 570 (BK/W) Dedicated Ground � PCM
52 � Not Used
53 924 (BR/O) PCM to Transmission Coast Clutch Solenoid
54 480 (P/Y) PCM to Transmission Converter Clutch Control
55 37 (Y) Battery to Load
56 191 (LG/BK) PCM Top Vapor Management Valve � Constant Current
57 310 (Y/R) Knock Sensor No. 1 to PCM
58 679 (GY/BK) Vehicle Speed Sensor � Positive to PCM
59 917 (DG/LG) Misfire Detection Sensor � Feed
60 74 (GY/LB) Heated Exhaust Gas Oxygen Sensor No. 1 to PCM
61 � Not Used
62 � Not Used
63 � Not Used
64 199 (LB/Y) Manual Lever Position Sensor to PCM
65 352 (BR/LG) Delta Exhaust Pressure Transducer to PCM
66 � Not Used
67 � Not Used
68 � Not Used
69 � Not Used
70 190 (W/O) PCM to Air Management No. 1 (Was TAB)
71 361 ® Power Output from PCM Relay
72 561 (T/R) PCM to Fuel Injector No. 7 Cylinder
73 559 (T/BK) PCM to Fuel Injector No. 5 Cylinder
74 557 (W) PCM to Fuel Injector No. 3 Cylinder
75 555 (T) PCM to Fuel Injector No. 1 Cylinder or Bank No. 1
76 570 (BK/W) Dedicated Ground � PCM
77 570 (BK/W) Dedicated Ground � PCM
78 � Not Used
79 911 (W/LG) PCM to Output Circuit Indicator Lamp/Overdrive Cancel Indicator
80 926 (LG/O) PCM to Fuel Pump Relay Control
81 925 (W/Y) PCM to Electronic Pressure Control No. 1
82 � Not Used
83 264 (W/LB) PCM to Idle Speed Control Motor No. 1
84 136 (DB/Y) Output Shaft Speed to PCM
85 � Not Used
86 � Not Used
87 94 (R/BK) Heated Exhaust Gas Oxygen Sensor No. 2 to PCM
88 See 967 (LB/R) Mass Air Flow Sensor to PCM
89 355 (GY/W) Throttle Position Sensor to PCM/Diesel Fuel Injector Pump Lever Sensor
90 351 (BR/W) Power to Engine Sensors
91 359 (GY/R) Sensor Signal Return
92 511 (LG) Stoplamp (Brake On/Off) Switch to Stoplamps
93 387 (R/W) HEGO Sensor Heater Voltage Monitor No. 1 to PCM
94 388 (Y/LB) HEGO Sensor Heater Voltage Monitor No. 2 to PCM
95 389 (W/BK) HEGO Sensor Heater Voltage Monitor No. 3 to PCM
96 � Not Used
97 361 ® Power Output from PCM Relay
98 562 (LB) PCM to Fuel Injector No. 8 Cylinder
99 560 (LG/O) PCM to Fuel Injector No. 6 Cylinder
100 558 (BR/LB) PCM to Fuel Injector No. 4 Cylinder
101 556 (W) PCM to Fuel Injector No. 2 Cylinder or Bank No. 2
102 � Not Used
103 570 (BK/W) Dedicated Ground � PCM
104 � Not Used
DTCs P0172, P0174, P0171 AND P0175: FUEL SYSTEM AT THE CORRECTED ADAPTIVE LIMITS
Diagnostic Trouble Codes (DTCs) P0171 bank (1) (cylinder #1) and DTC P0174 bank (2) indicate the fuel/air ratio is too lean.
miesk5 NOTE; FORD'S naming convention is that bank one is the same bank as where the number one cylinder is; sensor one and two are in the Y before the cat & sensor 3 is after the cat.
The fuel adaptive system is at the rich correction limit.
DTCs P0174 and P0175
Possible causes:
Fuel system;
Excessive fuel pressure.
Leaking fuel injector(s).
Leaking fuel pressure regulator. Pull vacuum hose off, any fuel or aroma, replace FPR.
Low fuel pressure.
Contaminated injector(s)
Induction system:
Air leaks after the MAF. check tubes from MAF TO TB
Vacuum leaks. See my Vacuum leak test @ Help with dtc codes and idle ... post #11.
Part 2 due to character limit bs
Restricted air inlet from atop radiator support through air filter through throttle body. Check air intake for leaks, obstructions and damage.
Fuel purge system. Check vapor cannister, hoses to Vapor Management Valve (VMV) & TB.
Improperly seated dip stick.
EGR, Leaking gasket. Stuck open EGR valve. Leaking diaphragm
Base engine:
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2S's.
Verify integrity of the PCV system. Check vacuum hose & valve itself.
Are there any of the above concerns?
Yes SERVICE as necessary. RERUN Quick Test.
No, GO to Pinpoint Test Step DC25. If MAF reading is within specification, return to Pinpoint Test Step H42. Check MAF for contamination; see below)
*** Over oiled K&N Air filters can cause this *
H42 INITIATE KOER SELF-TEST
Key off.
Scan Tool connected.
Disconnect fuel vapor hose from TB and plug fitting at TB.
Start engine and run at 2000 rpm for 1 minute and return to idle.
Enter Key On Engine Running (KOER) Self-Test.
Are HO2S DTCs P1127, P1128 P1129, P1131, P1132, P1151 or P1152 present?
Yes If DTC(s) P1127, P1128, or P1129 are present, GO to Section 5A, Powertrain Diagnostic Trouble Code (DTC) Charts and SERVICE those DTCs first. If DTC(s) P0131 and/or P0151 are present in Continuous Memory, SERVICE DTC P0131 or P0151 in the order they are displayed. GO to H27.
All others, GO to H43.
No For DTCs P1130, P1150, P0171, P0174, P0172 and P0175:
GO to H43.
If DTC(s) P1132 and/or P1152 are no longer present, RECONNECT fuel vapor line. GO to HW43.
All others:
The fault that produced the DTC is an intermittent. GO to Pinpoint Test Step Z1 with the following data: HO2S-11, 21 PIDs and list of Possible Causes.
H43 CHECK FUEL PRESSURE
WARNING: THE FUEL SYSTEM IS PRESSURIZED WHEN THE ENGINE IS NOT RUNNING. TO PREVENT INJURY OR FIRE, USE CAUTION WHEN WORKING ON THE FUEL SYSTEM.
Key off.
Install fuel pressure gauge.
Verify vacuum source to fuel pressure regulator.
If engine will start:
Start engine and idle. Record fuel pressure.
Increase engine speed to 2500 rpm and maintain for one minute. Record fuel pressure.
No Start:
Cycle key on and off several times. Record fuel pressure.
Is the fuel pressure between 30-45 psi (210-310 kPa)?
Yes Fuel system is capable of required fuel pressure. GO to H44.
No Fuel pressure out of specification. GO to Pinpoint Test HC.
H44 CHECK SYSTEM ABILITY TO HOLD FUEL PRESSURE
Fuel pressure gauge installed.
Verify there are no external leaks (repair as necessary).
Does the fuel pressure remain within 5 psi of the highest reading after one minute?
Yes For DTCs P1130, P1150, P0171, P0172, P0174 and P0175: GO to H45.
For No Starts: GO to H46.
For fuel control DTCs displayed with misfire DTCs: GO to H47.
All other DTCs: GO to H51.
No No Excessive pressure loss. GO to Pinpoint Test Step HC3.
H45 CHECK SYSTEM ABILITY TO HOLD FUEL PRESSURE WITH KEY ON
Cycle key on then off several times.
Turn key on and engine off, monitor fuel pressure gauge.
Does the fuel pressure remain within 5 psi of the highest reading after 10 seconds?
Yes For DTCs P1130, P1150, P0171 and P0174: GO to H47.
No For DTCs P0172 and P0175: GO to H49.
H46 CHECK ABILITY OF INJECTOR(S) TO DELIVER FUEL
Pressure gauge installed.
Cycle key several times.
Locate a6nd disconnect the Inertia Fuel Shutoff (IFS) Switch.
Monitor pressure gauge while cranking the engine for at least five seconds.
Was there a pressure drop greater than 5 psi (34 kPa) while cranking the engine?
Yes The EEC-V System is not the cause of the no start. REMOVE the fuel pressure gauge. RECONNECT the IFS switch. REFER to Symptom Flowcharts, Symptom Flowcharts, for further diagnosis.
No, REMOVE fuel pressure gauge. RECONNECT IFS switch. GO to H47.
Part 3
H47 CHECK RESISTANCE OF INJECTOR(S) AND HARNESS
Key off.
Disconnect PCM. Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
Note: This erases Continuous Memory DTCs.
Install breakout box, leave PCM disconnected.
Note: If misfire DTCs are displayed with the Fuel Control DTCs, use the misfire DTCs to determine the injector circuits requiring testing.
Measure resistance between suspect injector Test Pin(s) and Test Pin 71 or 97 at the breakout box using the chart below.
Cyl# Test Pin# Cyl# Test Pin#
1 75 5 73
2 101 6 99
3 74 7 72
4 100 8 98
Is the resistance between 11.0-18.0 ohms?
Yes Fuel injector and harness resistance is OK. GO to H50. No GO to H48.
H48 CHECK CONTINUITY OF FUEL INJECTOR HARNESS
Key off.
Breakout box installed, PCM disconnected.
Disconnect injector harness connector at the suspect injector.
Measure the resistance between Test Pin 71 or 97 at the breakout box and the VPWR pin at the injector harness connector.
Measure resistance between the Injector Test Pin(s) at the breakout box and the Injector Signal Pin at the injector connector. (Refer to chart in H47 for Injector Pin location.)
JIs each resistance less than 5.0 ohms?
Yes GO to H49.
No SERVICE open harness circuit. REMOVE breakout box. RECONNECT PCM and fuel injectors. RERUN Quick Test.
H49 CHECK INJECTOR HARNESS CIRCUIT FOR SHORT TO POWER OR GROUND
Key off.
Suspect fuel injector harness disconnected.
Measure resistance between the injector Test Pin(s) and Test Pin 71 or 97, 24, 76 and 103 at the breakout box (refer to chart in H47).
Measure the resistance between the Injector Test Pin(s) at the breakout box and chassis ground.
Is each resistance greater than 10,000 ohms?
Yes GO to H50.
No SERVICE short circuit. REMOVE breakout box. RECONNECT PCM and all fuel injector(s). RERUN Quick Test.
H50 CHECK INJECTOR DRIVER SIGNAL
Requires standard 12 volt test lamp.
Key off.
Breakout box installed.
Connect PCM to breakout box.
Connect test lamp between Test Pin 71 or 97 and each injector Test Pin (refer to chart in H47).
Crank or start engine.
Note: Properly operating system will show a dim glow at idle on the test lamp.
Does test lamp have a dim glow while cranking or running engine?
Yes REMOVE breakout box. RECONNECT PCM. GO to H51.
No, No light/Continuous bright light. REPLACE PCM. REMOVE breakout box. RERUN Quick Test.
H51 FLOW TEST FUEL INJECTOR(S)
Flow test fuel injector(s).
Use the Rotunda Injector Tester 164-R3750, SBDS Injector Tester or equivalent to flow test the injectors according to the instructions for the injector tester.
Is the leakage and flow within specification?
Yes DTCs P0171, P0172, P0174 and P0175: The fault that produced the DTC is an intermittent. GO to Pinpoint Test Step Z1 with the following data: SF1, SF2, LFT1, LFT2 PIDs and list of possible causes.
No REPLACE injector. RERUN Quick Test.
Z1 INTERMITTENT TEST PROCEDURE
Note: All Intermittent Procedures are used in conjunction with the Intermittent Symptom Charts and the Typical Diagnostic Reference Values at the end of the pinpoint.
If directed here from another pinpoint test, refer to PIDs, circuits or components that were recommended or else refer to the Symptom Chart at the end of the pinpoint for the proper selection.
Based on the Intermittent Prioritization Chart, choose an Intermittent Diagnostic Procedure below:
Input Test - This test is used on sensing devices such as temperature, position, oxygen, etc.
Output Test - This test is used on output devices such as relays, coils, solenoids, etc.
Water Soak Test - This test is used on both input and output devices. Especially useful on spark plug wires, relays and hall effect sensors.
Road Test - This test is used on both input and output devices. Four modes of engine operation are monitored for intermittent.
Note: The electronic ignition (EI) system tester is not capable of diagnosing coil on plug (COP) systems.
Ignition Test - This test is for non coil on plug only and used to diagnose the ignition system using the Electronic Ignition (EI) System Tester. Coil on plug applications will use the input, output, water soak and road test only. Select the next priority from the intermittent prioritization chart.
Have you chosen an Intermittent Diagnostic Test procedure?
Yes for the Input Test: GO Z10.
For Output Test: GO to Z20.
For Water Soak Test: GO to Z30.
For Road Test: GO to Z40.
For Ignition Test: GO to Z50.
No To diagnose other driveability symptoms, GO to Symptom Flowcharts, Symptom Flowcharts.
Z10 INTERMITTENT KOEO INPUT WIGGLE PROCEDURE
WARNING: USE CAUTION WHEN PERFORMING ANY OF THE TEST STEPS. ALWAYS BE AWARE OF HANDS, CLOTHING OR TOOLS NEAR COOLING FANS, ENGINE DRIVE BELTS OR HOT SURFACES.
Key off.
Connect Scan Tool to DLC.
Access PIDs based on information from the pinpoint test or Intermittent Symptom Charts at the end of this pinpoint test.
Go to the area of the suspected wiring or component fault.
Key on, engine off.
If input is a switch-type component, turn on manually.
Lightly tap on component while viewing PID values. Wiggle and pull each component wire (Signal, Signal Return and VREF, if applicable) at the component.
Look for abrupt changes in PID values. Compare the actual PID values to the KOEO Diagnostic Reference PID Values at the end of this pinpoint test.
Part 4
Are any PID values out of range or suddenly drop out and back into range?
Yes Possible wiring or component problem. CHECK each wire for corrosion, bent or loose terminals and poor wire terminal crimps. SERVICE as necessary. Otherwise, REPLACE component. VERIFY repair. If unable to verify, REINSTALL original part and GO to Z11.
No GO to Z11 for PCM wiring check
Key off.
Key on, engine off.
No GO to Z11.
Z11 INTERMITTENT KOEO INPUT WIGGLE PROCEDURE
Continue to monitor the information from the previous step.
Turn ignition key to the ON position.
Wiggle and pull each sensor wire (Signal, Signal Return and VREF, if applicable) from the component back to the PCM connector.
Look for abrupt changes in PID values. Compare the actual values to the KOEO Diagnostic Reference PID Values.
Yes Possible wiring or component problem. CHECK each wire for corrosion, bent or loose terminals and poor wire terminal crimps. SERVICE as necessary. Otherwise, if the value dropped out while checking the PCM harness connector and there is no evidence of a fault, REPLACE PCM. If unable to verify, REINSTALL original PCM. Return to Z1 and choose another procedure to follow. Unable to verify fault.
No GO to Z12 KOER Wiggle Test.
Part 5
Z12 INTERMITTENT KOER INPUT WIGGLE PROCEDURE
Key off.
Access PIDs based on information from the pinpoint test or from the Intermittent Symptom Chart.
Key on, engine running.
Lightly tap on component while viewing PID values. Also wiggle and pull each component wire (Signal, Signal Return and VREF, if applicable) at the component.
Look for abrupt changes in PID values. Compare the actual values to the HOT IDLE Diagnostic Reference PID Values.
Yes Possible wiring or component problem. CHECK each wire for corrosion, bent or loose terminals and poor wire terminal crimps. SERVICE as necessary. Otherwise, REPLACE component. VERIFY repair. If unable to verify, REINSTALL original part, and GO to Z13.
No GO to Z13 for PCM wiring check.
Z13 INTERMITTENT KOER INPUT WIGGLE PROCEDURE
Wiggle and pull each component wire (Signal, Signal Return and VREF, if applicable) from the component back to the PCM connector.
Yes Possible wiring or component problem. CHECK each wire for corrosion, bent or loose terminals and poor wire terminal crimps. SERVICE as necessary. Otherwise if the value dropped out while checking the PCM harness connector and there is no evidence of a wiring fault, REPLACE PCM. If unable to verify repair, REINSTALL original PCM and RETURN to Z1 and choose another procedure to follow.
No Unable to verify fault. RETURN to Z1 and choose another procedure to follow.
Hold off on following!
Test & Overview, W/Differential Pressure Feedback (DPFE) Sensor
by Mike N at smpcorp.com via web.archive.org
SLOW TO LOAD, so I'll give you the text here;
MIESK5 NOTE: only 95 5.8L California models & all 96 have the DPFE Sensor instead of EGR Valve Position Sensor (EVP) & Trucks never used a Pressure Feedback Exhaust (PFE) Sensor
TV"...The first step is to perform a thorough visual inspection of the system. If the inspection reveals nothing obvious, then some diagnostics are in order. Install a vacuum gauge in the vacuum line between the EGR valve and the control solenoid. Next, run the Key On-Engine Running self test. At one point during the self test, the PCM will check the EGR system by applying vacuum to the EGR valve. It accomplishes this by grounding the EGR regulating solenoid at a duty cycle of approximately 30%. If you see that the vacuum gauge indicates a vacuum reading of a few inches or more, you can be sure that the PCM, wiring, vacuum lines, and the regulating solenoid are functional. If not, then you must investigate where the source of the problem lies. If you do get a vacuum signal, then, exit the self test. With the engine at idle, apply vacuum to the EGR valve with a vacuum pump. When you apply vacuum, you should notice a change in engine RPM, with the possibility that the engine may stall. If the engine RPM changes, then we know the EGR is working. If there are no changes, then either the EGR valve is not functioning, or, the EGR passages are blocked with carbon. If engine RPM does change, then our next step is to examine the DPFE (Differential Pressure Feedback) sensor. The three wires consist of a 5 volt reference (which is shared with other sensors), a sensor ground (which is also shared), and a dedicated signal or output wire which is connected to the PCM. The DPFE sensor measures the difference between the upstream pressure (exhaust side), and the downstream pressure (intake side). Both sides are separated by an orifice assembly which is a calibrated opening that exhaust gas flows through when the EGR valve opens (refer to diagram #1). The DPFE sensor should measure equal pressure on both sides with the EGR valve closed. This means that we can measure and compare the signal voltage at idle with the signal voltage at key on, engine not running. Under these two conditions, if we see a difference in voltage output, then the EGR valve must be open (normally it should not be open at idle, or, with the engine not running). When the EGR valve opens under normal conditions, the upstream pressure should begreater than the downstream pressure. If not, then one of the hoses of the sensor is either off or plugged, or the orifice is blocked. The signal of the DPFE sensor at idle ranges from .20 to .90 volts DC. The actual voltage will vary depending upon the vehicle. Any voltage reading that is out of that range at idle will usually set a fault code. A fault code will also set if the PCM does not see a sufficient voltage change when EGR operation is commanded. Testing of the DPFE sensor can be done by monitoring its output voltage while applying vacuum to the EGR valve. If you notice an RPM change, or, the engine stalls, and the output voltage does not change, then the sensor is suspect. This assumes that the reference voltage and ground circuits are good. Also, tap on the sensor LIGHTLY to see if the output voltage changes. If the output changes, then the sensor is suspect. The DPFE’s output voltage with "Key On, Engine Off" is between .30 and .60 volts DC. This figure is applicable to the sensor with the aluminum housing. Look for an output voltage that’s about .2 to .3 volts higher for the sensor with the black plastic housing. If you apply vacuum to the EGR valve with the engine at idle, you should notice a change in the sensor’s output voltage, as well as some change in the idle RPM. The common causes of sensor failure are contamination, and excessive exhaust backpressure. Contamination can be caused by exhaust by-products as well other problems such as coolant from a failed gasket. Moisture from condensation can also present problems. One final note about all EEC V OBD II systems: the EGR system will not set any codes as long as the ambient temperature sensor "sees" the temperature below 32°F. Under these conditions, it is likely that if condensation has occurred, it will freeze and create some type of problem.
Test, Vacuum Video in a 96 5.0, using a hand-held vacuum pump/gauge
Source: by Tony K (Boat Dude, Big Blue) at http://api.viglink.com/api/click?format=go&jsonp=vglnk_147377247401612&key=6ed47b392b9edfe394b9e89b72717104&libId=it1i0tmm01000bgv000MAbv6q70se&loc=http://www.fullsizebronco.com/forum/2674020-post2.html&v=1&out=http://www.supermotors.net/registry/media/586142&ref=https://www.google.com/&title=Ford Bronco Forum - View Single Post - Code P0171 Lean bank 1 (already seached)&txt=Test, Vacuum Video in a 96 5.0, using a hand-held vacuum pump/gauge Source: by Tony K (Boat Dude, Big Blue) at SuperMotors.net
For the hand-held vacuum pump/gauge, if you don't have or can't borrow one from pals, ck out parts stores or AZ's LOAN-A-TOOL® PROGRAM
Vacuum Pump, Gauge reads 0 to 30 inches of mercury.
MAF Servicing TSB 96-22-5 by Ford for 94-96 ISSUE: The Mass Air Flow (MAF) sensor is not designed to be removed from its body (die-cast or plastic) for servicing. The sensing elements located inside the by-pass tube can be damagedin by poking/probing/touching.
ACTION: Service the MAF sensor as an assembly (refer to Figure 1).
WARNING: DO NOT DISASSEMBLE THE MAF SENSOR.
by Ford ...
🔲Clean it anyway
MAF Cleaning, in a F 150 Source: by Dan N via How to clean the MAF (Mass Airflow Sensor) in a Ford F150
ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center:
... have VIN ready.
To confirm current status, use this guide by jowens1126 @ 93 & 94-96 Cruise Control Recalls Repair
Note that the 93 recall is different than the 94-96 recall.
Here's the 1996 Bronco/F-Series Workshop Manual partial
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @ https://www.ford.com/cmslibs/conten...sovers/bronco/pdf/96_Ford_Bronco_Brochure.pdf
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ 1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
Here's the character limit killer
P0411 @ https://www.broncozone.com/threads/trouble-codes-p0401-and-p0411.21838/#entry114154
DTC P0443 Description & Tests; Finding (& fixing) EVAP system leaks; "...If you can't detect a leak at the moment, record the data, clear the DTC and talk to the customer. There are a number of reasons why the system might not appear to be leaking when you test. Sure, the gas cap might be bad or may have been left loose. The gas tank may be too full to run an accurate test. Some leaks seal up when the temperature increases. You may need to retest the vehicle when it's cold..."
Source: by Ludlow B at motor.com
Here is the pin-point test by Ford
Check if the cap is loose or its gasket is stiff as a...a....a...
For troubleshooting without a breakout box, go to the EEC pin instead
Diagnostic Trouble Code (DTC) P0443 indicates a failure in the Vapor Management Valve circuit. Possible causes:
VPWR circuit open.
Vapor Management Valve open.
Vapor Management Valve shorted to PWR GND or SIG RTN.
Damaged Vapor Management Valve.
Damaged PCM.
Key off.
Disconnect Vapor Management Valve.
Key on, engine off.
Measure VPWR circuit voltage at Vapor Management Valve harness connector.
Key off.
Was voltage greater than 10.5 volts?
Yes GO to HW2. No REPAIR open circuit. RESTORE vehicle. COMPLETE PCM. Reset to clear DTCs. RERUN Quick Test.
HW2 CHECK Vapor Management Valve RESISTANCE
Measure Vapor Management Valve resistance.
Is resistance between 30 and 90 ohms (vehicles with test pin 67) or 30 and 38 ohms (vehicles with test pin 56)?
Yes GO to HW4.
No REPLACE Vapor Management Valve
HW4 CHECK Vapor Management Valve CIRCUIT FOR OPEN IN HARNESS
Measure resistance between PCM test pin 67 or PCM test pin 56 and EVAP canister purge circuit at the Vapor Management Valve harness connector.
Is resistance less than 5.0 ohms?
Yes GO to HW5.
No REPAIR open circuit. RESTORE vehicle. COMPLETE PCM Reset to clear DTCs. RERUN Quick Test.
HW5 CHECK Vapor Management Valve CIRCUIT FOR SHORT TO PWR GND IN HARNESS
Disconnect scan tool from DLC.
Measure resistance between PCM test pin 67 or PCM test pin 56 and PCM test pins 24 and 103.
Are both resistances greater than 10,000 ohms?
Yes GO to HW22.
No REPAIR short circuit. RESTORE vehicle. COMPLETE PCM Reset to clear DTCs. RERUN Quick Test.
HW22 22 CHECK Vapor Management Valve CIRCUIT FOR SHORT TO VPWR IN HARNESS
Measure resistance between PCM test pin 67 or PCM test pin 56 and PCM test pin 71.
Is resistance greater than 10,000 ohms?
Yes REPLACE PCM. RESTORE vehicle.
Access the Vapor Management Valve PID ( VMV PID )on the scan tool. DRIVE vehicle (including a steady accelerator speed over 80 km/h (50 mph) until the VMV PID shows 75 percent duty cycle). Then maintain approximate speed until duty cycle reaches zero percent. After additional two minute drive, bring vehicle to an idle. RERUN Quick Test.
Access the VMV PID on the scan tool. DRIVE vehicle (including a steady accelerator speed over 80 km/h (50 mph) until the VMV PID shows 75 percent duty cycle). Then maintain approximate speed until duty cycle reaches zero percent. After additional two minute drive, bring vehicle to an idle. RERUN Quick Test.
EEC-V Pin #/PID only is 56
Measured/PID Values Units Measured/PID
KOEO is 0
Hot Idle is 0
30 MPH is 0-10
55 MPH is 0-10
Units Measured/PID Hz
PCM Connector Pin-Out Diagram with Circuit Functions in a 96 5.0 and 5.8
Pin Number Circuit Circuit Function
3 � Not Used
4 � Not Used
5 � Not Used
7 � Not Used
8 � Not Used
9 � Not Used
10 � Not Used
11 � Not Used
12 � Not Used
17 � Not Used
18 � Not Used
19 � Not Used
20 � Not Used
21 � Not Used
22 � Not Used
24 570 (BK/W) Dedicated Ground � PCM
26 � Not Used
28 � Not Used
30 � Not Used
31 � Not Used
32 � Not Used
34 � Not Used
42 � Not Used
43 � Not Used
45 � Not Used
46 � Not Used
52 � Not Used
61 � Not Used
62 � Not Used
63 � Not Used
66 � Not Used
67 � Not Used
68 � Not Used
69 � Not Used
71 361 (R) Power Output from PCM Relay
78 � Not Used
82 � Not Used
85 � Not Used
86 � Not Used
88 967 (LB/R) Mass Air Flow Sensor to PCM
96 � Not Used
97 361 (R) Power Output from PCM Relay
102 � Not Used
104 � Not Used
VPWR circuit open.
Damaged PCM.
Key off.
Key on, engine off.
Key off.
Yes GO to HW4.
Yes GO to HW5.
Yes GO to HW22.
KOEO is 0
Hot Idle is 0
30 MPH is 0-10
55 MPH is 0-10
3 � Not Used
4 � Not Used
5 � Not Used
7 � Not Used
8 � Not Used
9 � Not Used
10 � Not Used
11 � Not Used
12 � Not Used
17 � Not Used
18 � Not Used
19 � Not Used
20 � Not Used
21 � Not Used
22 � Not Used
26 � Not Used
28 � Not Used
30 � Not Used
31 � Not Used
32 � Not Used
34 � Not Used
42 � Not Used
43 � Not Used
45 � Not Used
46 � Not Used
52 � Not Used
61 � Not Used
62 � Not Used
63 � Not Used
66 � Not Used
67 � Not Used
68 � Not Used
69 � Not Used
78 � Not Used
82 � Not Used
85 � Not Used
86 � Not Used
96 � Not Used
102 � Not Used
104 � Not Used
All that made my head spin. Sure glad I have 78.s
P
Prescott Bronco
Prescott Az
VPWR circuit open.
Damaged PCM.
Key off.
Key on, engine off.
Key off.
Yes GO to HW4.
Yes GO to HW5.
Yes GO to HW22.
KOEO is 0
Hot Idle is 0
30 MPH is 0-10
55 MPH is 0-10
3 � Not Used
4 � Not Used
5 � Not Used
7 � Not Used
8 � Not Used
9 � Not Used
10 � Not Used
11 � Not Used
12 � Not Used
17 � Not Used
18 � Not Used
19 � Not Used
20 � Not Used
21 � Not Used
22 � Not Used
26 � Not Used
28 � Not Used
30 � Not Used
31 � Not Used
32 � Not Used
34 � Not Used
42 � Not Used
43 � Not Used
45 � Not Used
46 � Not Used
52 � Not Used
61 � Not Used
62 � Not Used
63 � Not Used
66 � Not Used
67 � Not Used
68 � Not Used
69 � Not Used
78 � Not Used
82 � Not Used
85 � Not Used
86 � Not Used
96 � Not Used
102 � Not Used
104 � Not Used
Broncosandpartsgarage
Michigan
Usually when you OD switch is blinking it’s a bad VSS but more often your PSOM is toast. Easy fixes.
stevedave
