Fuel line search frenzy!
broncostyle
Terrytown, Louisiana
Hello my bronco buddies,i am looking for the preformed fuel line that goes from the fuel pump that is in the tank that goes to the filter that is located in the chassis. it has the quick connect ends. I have looked at the Ford dealership,they say its discontinued, i also checked the aftermarket companies and 2 companies that make up the lines but they were unable to locate the kind of ends i need. Is their any other alternatives
yo broncostyle,
What year and engine?
Also did you contact these firms?;
Jeff's Bronco Graveyard - Nylon Fuel Line Connector Repair Kit 90 Degree; Nylon Fuel Line Connector Repair Kit Straight W/Union; Nylon Fuel Line Connector Repair Kit Straight /16" Quick Connector, Straight w/ 18" of 3/8" Nylon Tube and a Union
http://broncograveyard.com/bronco/c-1511-straps-parts.html
Inline Tube - Bronco/Ford truck pre-formed brake, power steering & transmission cooler line sets, hoses, fittings, & rubber fuel hoses, etc.; exhaust systems; parking brake cables; gas tanks, etc. Call them since not all parts are shown on-line Inline tube exclusively CNC manufactures all the hard to find fittings. If your original fitting has a long hex, deep thread, or any kind of special feature, you can be assured we will have an exact replacement on your line. Inline Tube DOES NOT substitute generic fittings on any line. Spring wrap (armor guard) and black cloth wrap is also installed in the same locations as your original lines. Inline Tube makes tubing products in the following sizes: 1/8", 3/16", 1/4", 5/16", 3/8", 7/16" and 1/2". The stainless tubing features a bright unmarked finish and the steel tubing is coated with a tin/galvanized rust protection just like the OEM original.
http://www.inlinetube.com
FMSI - air conditioning, brake & fuel lines & fittings; Bronco/Ford truck door hinge pins & striker bolt assy; mini blocks & pins & terminals, pig tails - Ford / Chrysler repairs, rusted and leaking fuel lines
OEM style flare with viton O-ring (Brown)
http://catalog.fmsiinc.com/viewitems/repair-lines/steel-fuel-repair-lines?&bc=100%7C1002%7C1059
http://www.mypartshop.com/
Select;
All Parts
year, etc, then FORD TRUCK
Fuel Lines
Zip Code;
my Comcast is dead slow again so, I was timed out, but got one hit;
92
BRONCO Fuel Lines
5.0 04-92 0 130015
78575 0.0 Call 1881 Call Oregon & A to Z Auto Wrecking
503-653-8181
800-769-6893
Dan
503-653-8181
800-769-6893
1209 SE 190th Ave
Portland OR 97233
[email protected]
or
http://www.copartfinder.com
Has Vehicle Pics!
http://www.picknpull.com
http://www.car-parts.com/
Also for obsolete parts;
Our Sponsor here has been adding some to inventory; Jeff's Bronco Graveyard
and: by Ford pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
Also; fyi & Posterity;
Nylon Fuel Line Service Procedure TSB 92-12-16 for 86-92 Bronco, Aerostar, Econoline & Ranger; 91-92 Explorer; 85-92 F-150-350; 88-92 Super Duty; 86-90 Bronco II
Source: by Ford via Chilton
http://content.chiltonsonline.com/TSB/displayTSBHandler.ashx?assetID=36152&key=6kAUBD5BruOJf%2f3tgozUqjXM3RdbjcQqW4sVWiE%2fp2IojfpfKqM07dr61%2bQAWHtTJ1N7Mgu3AvSabLSypE3tQGB%2fp0cZmt8BpRktsy43U1h5CUze4jzam8KItXnQTE0cEhIQpMOJySNYo4EjAyn0Vw%3d%3d
broncostyle
Thank you so much miesk5 for all of your researched info, I have the 96 Eddie Bauer edition with the 5.8 Windsor Eng. i Have call the bronco graveyard, he put me in touch with in line tube ,but no luck other than mailing my fuel line for him to duplicate. i will try the salvage yards today. Are the f series compatible with the broncos? Due to the amount of rust, I'm thinking of another fuel tank as well.
broncogirl6249
Did you have any luck finding the fuel line? I have the same exact bronco and need to replace replace the lines and filter. I'm having issues with the lines.
Yo BG,
From other friends that need same due to butchering the filter replacement; best source is a yard queen.
Wdtdls
