HELP with self test on EEC for 351w
Medic2DaResq
Oklahoma
Please, some one help. I need to run a self test on my Bronco, but not sure how do do this, book is a little confusing. :blink:
yo Medic2DaResq,
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
 Some basics;
Do KOEO test First
 KOEO
 KOER
 GL!
M
Medic2DaResq
Oklahoma
Thank you very much for that info,I'll be back after while, gonna go get this done.
M
Medic2DaResq
Oklahoma
Ok.I have completed the self test, maybe you can help me translate them.
KOER results= 72 ( think) I got 4 quick flashes,pause,1 quick,longer pause,7quick,short pause,2 quick,pause 1 quick,pause,7 quick-2 quick and that was all it gave me.
KOEO results= not sure, I got 1 flash,1 flash,1 flash,1 flash,1 flash,1 flash,1 flash with about 1 sec delay in between,then long pause 7 quick,2 quick,2 quick,then 1 flash,2 quick,1 flash, 7 quick,2 quick,2 quick,1 flash,2 quick and no more.Can you help me?
yo Medic2DaResq,
Sorry for the delay in replying, I had to get some body work done (not on the Bronco, my bod..lol)
Fast DTCs are issued before slow service DTCs. These DTCs contain the identical information as the slow DTCs, but are transmitted at 100 times the normal rate. These DTCs are interpreted by special equipment at the end of the assembly line by the Body and Assembly Division, as well as the SUPER STAR II tester. After Fast DTCs have been output, Self-Test should not be exited (remove jumper, unlatch button, etc.) until all the Slow DTCs have been output. Exiting before slow DTCs have been output will erase any Continuous Memory DTCs.
Some meters in service detect these codes as a short burst of information (slight meter deflection).
Ryan M also addresses this in his self test @
http://oldfuelinjection.com/?p=13
When the “Check Engine” light blinks during the test you will get several different blinks, the separation time between blinks is used to indicate what information is being displayed.
Turn key to RUN.
You will hear some relays engage and the fuel pumps prime the system. This is the EEC beginning the test.
The fuel pumps will stop and the EEC will now begin giving codes.
You may catch a brief flickering of the light. This is a rapid code read that is used by the code readers you can purchase. Do not worry all those rapid flashes you just say flicker buy will now be given at a slower pace of �, 2, & 4 second pauses.
First digit of first KOEO code (1/2 second between blinks)
2 second pause
Second digit of first KOEO code (1/2 second between blinks)
4 second pause
Next KOEO code
Once all KOEO codes are read the EEC will repeat them
6 second pause
Single Separator Blink (this indicates the change from KOEO codes to CM codes)
6 second pause
Codes from Continues Memory (uses same 1/2, 2, and 4 second timing as KOEO codes and also repeats them)
If nothing has been recorded by the EEC since last battery disconnect you will see:
Blink – 2 sec – blink – 4 sec – blink – 2 sec – blink – 6 sec – blink – 6 sec – blink – 2 sec – blink – 4 sec – blink – 2 sec � blink
This translates into 11-11 current condition (KOEO) and 11-11 in the continues memory (CM); or SYSTEMPASS
This may seem hard to count; recommendation is to record codes with slashes, and to lump them all together. Sort them out into numerical codes later. Here is an example of this
RR-Texas
Houston, Texas
I picked up a reader at the auto parts for $35 I think that gives the code number which might be easier to use in the future? Looks like miesk5 has you hooked up, he is very helpful with a lot of information!
eholt80
