wiring harness
Captain D
New Orleans
What is the harness that is attached to the right side of the dash panel that's just screwed on to it? It is on right side of steering wheel opposite the rear window switch. The panel is over the gaauges.
What year truck do you have? Put your trucvk vitals in your signature, it will help get mor meaningful answers. :) /emoticons/[email protected] 2x" width="20" height="20" />
C
Captain D
New Orleans
I couldn't figure out how to add another vehicle to my profile, anyway it is a 96 xlt 5.0 with manual hubs and manual 4 wheel shift.
This is that fuel tank selector switch & wiring pic as Ron mentioned;
http://i261.photobucket.com/albums/ii51/tomtoc/93F150/ClusterSwap/IMG_2627.jpg
Instrument Panel Wiring in a 96
Item Part Number Description
1 — Wiring to Headlamp Switch
(Part of 14401)
2 — Wiring to Fuse Box
(Part of 14401)
3 14A282-CB Retainer
4 N606678-S36 *****
5 12A581 Engine Control Sensor Wiring
6 — Connector to 14A504
(Part of 14401)
7 13K359 Multi-Function Switch
8 — Connector to Stoplamp Switch (Part of 14401)
9 — Clip
10 — E4OD Pigtail
(Part of 14401)
11 — Connector to Park Lamp Signal Switch
(Part of 14401)
12 14405 Rear Lamp Wiring
13 — Wiring to Ignition Switch and Steering Column
(Part of 14401)
14 — Connector to Clutch Interlock Switch
(Part of 14401)
15 — Wiring to Remote Keyless Entry Module
16 — Connector to Warning Buzzer Chime (Part of 14401)
17 — Connector to Remote Keyless Entry Module
18 — Air Bag Module
19 — Connector to Overspeed Warning (Part of 14401)
20 — Connector to Trailer Brake Connector (Part of 14401)
21 14A099 Wiring Shield (2 Req'd)
22 — Vacuum Hose Clip
23 — Connector to Ash Receptacle Wiring
(Part of 14401)
24 — Connector to PSOM Test Circuit (Part of 14401)
25 14A265 Connector to 14A265 Wiring Assembly
26 14B095 Connector to 14B095 Wiring Assembly
27 18A586 Connector to 18A586 Wiring Assembly
28 — Connector to Right Courtesy Lamp Switch (Part of 14401)
29 — Connector to Inertia Switch (Part of 14401)
30 — Wiring to Ground
(Part of 14401)
31 — Connector to Clearance Lamp (Part of 14401)
32 — Connector to Wiper Control Module (Part of 14401)
33 — Wiring to Rear Brake Anti-Lock Control Module (Part of 14401)
34 — Wiring to Glovebox Lamp (Part of 14401)
35 — Wiring to Brake Anti-Lock Module Test Circuit
(Part of 14401)
36 — Wiring to Radio Antenna (Part of 14401)
37 — Wiring to Bowden Cable
(Part fo 14401)
38 — Wiring to Cigar Lighter
(Part of 14401)
39 — Wiring to Heater Mode Switch (Part of 14401)
40 — Wiring to A/C Illumination
(Part of 14401)
41 — Connector to Radio
(Part of 14401)
42 — Wiring to A/C Blower Switch (Part of 14401)
43 — Wiring to Power Point
(Part of 14401)
44 — Connector to Premium Sound Amplifier (Part of 14401)
45 — Wiring to Shift on the Fly Switch (SOF)
(Part of 14401)
46 14A262 Wiring to Electric Defroster (Bronco)
47 14401 Main Wiring
48 — Take-Out to SOF Switch, and Electric Defrost Switch
(Part of 14401)
49 — Wiring to Cluster (Plug A)
(Part of 14401)
50 — Wiring to PSOM
(Part of 14401)
51 — Wiring to Cluster (Plug B)
(Part of 14401)
52 14B155-BA Cap
53 04320 Instrument Panel
54 — Connector to Dual Fuel Tank Switch (Part of 14401)
55 — Connector to Rear Window Control Switch (Bronco) (Part of 14401)
56 — Demister Hose
(Part of 04320)
C
Captain D
New Orleans
(Part of 14401)
(Part of 14401)
4 N606678-S36 *****
(Part of 14401)
9 — Clip
10 — E4OD Pigtail
(Part of 14401)
(Part of 14401)
(Part of 14401)
(Part of 14401)
18 — Air Bag Module
(Part of 14401)
(Part of 14401)
(Part of 14401)
(Part fo 14401)
(Part of 14401)
(Part of 14401)
(Part of 14401)
(Part of 14401)
(Part of 14401)
(Part of 14401)
(Part of 14401)
50 — Wiring to PSOM
(Part of 14401)
(Part of 14401)
52 14B155-BA Cap
56 — Demister Hose
(Part of 04320)
The harness I am talking about is on the right side of steering wheel on same dash panel as rear window switch. It is screwed to the panel as the window switch looks like area where there would be a clock.
yo CAPT.
In the diagram I posted above;
(Part of 14401)
is the 4x4 High/Low Range Shift Buttons as shown in this pic by Steve
Steve labeled it as the "T-Case Switch"
and w/Switch in panel by Steve
If that is not it, then snap a pic or 3 with wiring colors...
figjeti
