High RPMS after start
WileE7
When I start my Bronco the engine idles at 2100 rpms for about 1min and 15sec then it drops down to 1000 30secs after that it flucuates between 700-1000. I know this isnt normal where do i need to start?
My guess would be.
First check for a vacuum leak
Next consider TPS.
I'd check for vacuum leaks, then pull codes
Pull Diagnostic Trouble Codes (DTCs) From your onboard computer.
Your engine and transmission are computer controlled.
The computer uses sensors to tell it a number of different things and it controls actuators that push or pull mechanical levers (kinda). If one or more sensors aren't working properly, the computer goes "blind" and doesn't know what to do. If the computer can "see" but one of the actuators is broken and therefore can't follow the commands of the computer; the engine won't run correctly. The computer is preprogrammed with set values for each of its sensors, and each of its actuators. It will run a self check of all systems, like the space shuttle; it will compare its set value(s) to the value(s) it recieves from its sensors, and actuators. If any sensor or acutator is out of the "normal" range the computer will generate a "code." It will generate some codes on the fly, and others will be stored while you are driving. There is a simple method to "pull codes" out of the computer for one to use for diagnostic purposes.
Earlier versions of On Board Diagnostics OBD 1983-1995 can flash the error code to the dash board and can be pulled in one's driveway without any special tools.
Later versions of On Board Diagnostics OBDII some 1995, and pretty much all 1996 and newer, require one to use a code reader or scanner tool.
Some auto parts stores will scan your engine codes for FREE, you may want to call around. Some will scan OBDII but not the older (prior to 1996) OBD systems.
SO here you go...
How to scan FORD on board Diagnostic Trouble Codes (DTCs) in your driveway
HowTo Pull Codes 1983-1995 Broncos, Mustang, F series Trucks, Econolines, 302, 351 and more
WileE7
WileE7
My guess would be.
Next consider TPS.
SO here you go...
Whats the best way to do the vac check?
69bronc347
southern michigan
im my opinion the best way to vacuum leak check is with a can of brake clean, just make sure your plug wires are good or you could have a small fireball, but spray all vacuum line and the manifold, and listen for the rpm's to increase. if the idle concern is not vacuum related i would put an iac on the vehicle, then set the idle, to do this you will leave the iac unplugged, set the idle to the specified range with the throttle stop, then set your tps to be .4to .7 output voltage then plug in your iac and the process is complete
eholt80
