Brake pedal wont come up all the way (1986)
Hossrod
I just bought an 86 bronco and it appears to of had a bad water leak in the past and sat for awhile with water coming in from the windsheild someplace. It seems the water ran down the inside of the dash and maybe through the brake and clutch pedal support (where the pedals pivot).
Anyways, I disconnected the master cylinder pushrod from the brake pedal and the brake petal is pretty stiff to move. When I move the clutch pedal, the brake pedal moves with it. I can move them seperatly, just stiff. I have a feeling the water has caused rust/corrosion inside the braket pedal support. I've tried spraying **** in the right and left side, but doesn't seem to be helping much.
How hard is it to take this assembly out and apart so I can clean and grease it? I'm not even sure how its held in there. I can't see any bolts or anything. It looks like its attached to the dash frame, i hope it doesn't involve taking aout the entire dash!
Here is a photo. You can see the **** I sprayed and how the **** turned brown due to rust.
Thanks for any help!!
Welcome to the Zone!
I believe you have this issue as well; some info may help; and some repair LINKs are in my site that may help;
Clutch Cracks Firewall TSB 90-16-7 for 84-90 Bronco & F Series Source: by Ford via terrapinmfg.com
It is a PDF file
"...12. Check the cross shaft bushings for wear if the brake pedal moves when the clutch is depressed
and vise versa. Replace them as required. NOTE: GENERALLY, TRUCKS WITH SIGNIFICANTLY LESS THAN 11 MM CLUTCH
RELEASE BEARING TRAVEL (AFTER COMPLETING THE INSPECTION PROCEDURE AND CORRECTING WHERE NECESSARY) WILL HAVE SIGNIFICANT DASH DAMAGE FROM PULLED SPOTWELDS AND TORN METAL. THESE TRUCKS WILL REQUIRE EXTENSIVE REPAIR. THEREFORE, GO TO THE LARGE REINFORCEMENT INSTALLATION PROCEDURE..." There are two small reinforcement kits. One for 1988 and later models and one for 1987 and prior models.
This is necessary because a new hydraulic clutch master cylinder mounting pattern was introduced for 1988
models.
1987 And Prior Trucks
Use reinforcement kit E3TZ-7K509-A on these trucks, Figure 5. Comprehensive installation instructions
are included in this kit.Firewall Reinforcement Plate & Bracket Source: by Terrapin Manufacturing
Firewall Reinforcement Kit & Actuating Rod Installation Source: by riotwarrior
He pulled pedal assy out and wrote; "... removed the steering column and foot pedal assembly along with the instrument cluster and this is all covered in the TSB so I won’t get into the details on how to do this here. My concern is the actual plate and it’s installation..."
I did it again and over-wrote the following;
these are from Steve83 in his Clutch Album: He repalced his tranny w/86
clutch linkage assy diagram 80-96 Bronco
Just one of MANY reasons why this mechanical linkage sucks.
The only solution was a later pedal shaft with splines, so I found an '86 shaft & pedal.
and from;
"...CLUTCH PEDAL Removal Disconnect pedal return spring from pedal and bracket. Unhook barbed end of clutch/starter interlock switch from pedal. Remove clutch pedal after removing retaining nut on end of shaft. Remove bushing from pedal shaft. Installation Install bushing on shaft. Place pedal on shaft and tighten nut. Install return spring. Make sure spring is hooked to pedal and bracket securely. Insert barbed end of interlock switch rod into bracket. Check and adjust interlock switch if necessary...."
by Dave H at http://www.2carpros.com/questions/ford-bronco-1986-ford-bronco-hydraulic-clutch
in reply to; 1986 Ford Bronco hydraulic clutch
Transmission problem 1986 Ford Bronco 6 cyl Four Wheel Drive Manual 120000 miles needing to replace the hydraulic clutch and was needing to know how to do it. any info would be great.
Asked by lynn_s
H
Hossrod
SNIP Lots of good info SNIP
Thanks for the info! Some of the photos really help! Luckily I don't have the main issue described, just the shaft that passes through the tube is rusty/corroded. But the images will help me to see how its held in there and how to get it out (looks like I have to remove the steering column).
I don't have access to an interchange guide so,
EDIT; I found this info; "The change was in 92. by 89 most all trucks had same basic setup For clutch. I put a 88 set up in a 91 Bronco..." by DaveFor a YARD SEARCH on-line, I use;
http://www.mypartshop.com
Select All Parts
year, etc, then FORD TRUCK
then I selected; Brake-Clu Pedal Prt
I used Ohio as the state as an example;
86
BRONCO Brake-Clu Pedal Prt
5.0 AT 72 L3667
458886 0.0 Call 528 Call Medford Auto Wreckers Inc.
631-289-1772
631-289-xxxx
171 Peconic Avenue
Medford NY 11763
[email protected]
www.mawny.com
86
302 ATOD 4x4 49 A04986
157652 0.0 Call 1970 Call Bend Auto Recyclers Inc.
541-382-1987
800-754-1987
Dan
541-382-xxxx
800-754-xxxx
64154 North Highway 97
Bend OR 97701
[email protected]
www.peakswing.com
86
AUTO 0 SK9672
85661 0.0 Call 2042 Call Ace Auto Wrecking
360-423-xxxx
800-562-xxxx
eholt80
