4wabs on 94 bronco where can i get a new hcu
broncosam43
upstate new york
just like the title says my hcu went bad on my tuck i do have a parts bronco but i dont think that ones any good eitheir what can i do about it where can i get a new one or is there a way to bypass?
Yo!
Read this with at least one good Source, BBA REMAN; Hot link, 4WAB
broncosam43
upstate new york
Yo!Read this with at least one good Source, BBA REMAN; Hot link, 4WABS Testing by Steve83, etc is in this Link here at da Zone
http://broncozone.com/forums/index.php?showtopic=18882
well i did test it and it does test bad with it hooked completly up to the truck so i need a new one or rebuild on you it says that some people have used crown vic parts to fix one i have a grand marquis ( the marquis was the sister car to the crown vic ) which is just going in for scrap its a 99 i wondered if i could use the hcu from that ? i see you mention that in the other post, do you know anything about how to do that ?
broncosam43
upstate new york
Glad you were able to get one there Sam; when I called last summer, they said they didn't have any in stockand their supplier, Raybestos stopped rebuilding the HCUs.
Now I see you're getting the "abs module"?
I don't know if the 99 GM HCU ot ABS Module will work in your year Bronco; doubt it based on a Motorcraft pn search(es) I just did.
broncosam43
upstate new york
Glad you were able to get one there Sam; when I called last summer, they said they didn't have any in stockand their supplier, Raybestos stopped rebuilding the HCUs.Now I see you're getting the "abs module"?
it wouldnt be a gm one it would be a ford one mercury/ford same comapny gm would be genral motors do you know what other fords had that abs module on them
Well that was a typo on my part i actullaly i should be getting the abs modulator
broncosam43
upstate new york
it wouldnt be a gm one it would be a ford one mercury/ford same comapny gm would be genral motors do you know what other fords had that abs module on them Well that was a typo on my part i actullaly i should be getting the abs modulator
sorry i my part gm= grand marquis didnt click right away lol
Modulator? Sorry, I am stuck on .. ya know.
Ok, I know many Fords had them; and there is a diff in Bronco years; i.e. 94-96 Broncos are diff than a 93 Bronco. So Ford part numbers are da key in this sit.
later.. GL!
