Steering wheel shake.
BronBronBronco
Santa Clarita,CA
I have a 69 bronco with 3 on the tree and a 302. I had some bald tires on the Bronco so I found a great deal on a set of fairly new tires on some good rims.
After mounting the tires on the Bronco I took it for a drive down the street. About 20 miles an hour the steering wheel starts shaking so bad it feels like the front end or tire is falling off. Worse than a tire out of balance or bent rim. :( /emoticons/[email protected] 2x" width="20" height="20" /> I also just installed a rebuilt steering column today as well.So I motored it home slowly and at very low speed its ok. I looked at the drag link and it has alot of play in it. It looks like the original as it looks like it has a spring load at the ball joint new the pitman arm. Would this cause this eratic shake? Everything else looks ok.
pyro
I have a 69 bronco with 3 on the tree and a 302. I had some bald tires on the Bronco so I found a great deal on a set of fairly new tires on some good rims.After mounting the tires on the Bronco I took it for a drive down the street. About 20 miles an hour the steering wheel starts shaking so bad it feels like the front end or tire is falling off. Worse than a tire out of balance or bent rim. :( /emoticons/[email protected] 2x" width="20" height="20" /> I also just installed a rebuilt steering column today as well.So I motored it home slowly and at very low speed its ok. I looked at the drag link and it has alot of play in it. It looks like the original as it looks like it has a spring load at the ball joint new the pitman arm. Would this cause this eratic shake? Everything else looks ok.
i had the same problem on my 80 but i had to change all the front bushings
OhNo50
Bunnell FL
If one of the new rims are bent or out of balance it could just be causing a suspension problem to be noticed or more noticable. Does the shake go away at a certain speed or does it start at 20 and just get worse?
Broncoholics
Broncoholics
Washington State
Sounds like you tossed a weight off a wheel. Its very common for them not to be seated all the way and they will fly off on the road.
anisend09
United States
Its a pretty common issue, unfortunately. My answer to this will eventually be a re-upholstered in alcantara steering wheel rim. A guy near me
BronBronBronco
Santa Clarita,CA
It turned out to be that the previous owner adjusted the manual steering box adjuster in the wrong direction (down) causing the worm gears inside to have a lot of free play. In return causing the steering wheel to shake uncontrollably at speeds above 18 mph.
I bought a steering box out of a 75 and rebuilt it. Problem solved. :) /emoticons/[email protected] 2x" width="20" height="20" />
fred tyler
