Wiring short or ?
JMo3Stix
Parma Heights, OH
Recently my parking lights/tail lights have spiradically been coming on and staying on. I removed the fuse and it solved the problem. Bad thing is driving at night/early morning i have no tails unless i put the fuse back in. Could this be as simple as getting a new fuse or could it possibly be faulty wiring? Any help would be appreciated.
ez cks first
Check lamp sockets for Corrosion/bad wiring, etc.
Do you have a 12v test light or meter to ck for power on both side of fuse; at tail & park lights?
Do what Ford describes as a wiggle test; while cking for power; tap bulbs too; tap directional switch
Next check grounds;
Locations in an 82; 203 right front frame & engine block, 701 firewall behind radio, 801 left side of core support, 802 right side of core support, 804 behind left tail light, 805 behind right tail light, 751 behind left tail light Source: by Ryan M (Fireguy50)
I do not have a good wiring diagram; maybe someone else here can post it up for you; esp for directional switch - entire ckt.
