Will it bolt up?
BigBlue79
I have a 1979 Bronc. with a C-6 tranny behind a stock 460. The 460 locked down and I am in the process of rebuilding. I also have a 1974 330ci. that I would like to install for the time being. WILL IT BOLT UP???? Its in another vehicle(a 1974 Ford School bus) so I dont want to take it out until I'm sure it'll bolt up. Will it hook up to a C-4 or a C-6?
texan79&96
is 330 correct? are you talkin about the 300 big six ive never heard of a 330 did they come in trucks?
RTM
I have heard of a 370 which is a truck motor and if the 330 is the same as the 370 then it should be the same as the 460.
russhyped302
well i worked on a 87 ford f250 that had a 306 strait 6 and we put a c-6 tranny in that so mesure the bolts thats the way to find out for sure :)>-
4xfan78
Georgia, augusta
What ever size the donor engine is I do not think that it will just bolt up, unless you do some mods. to the motor mounts.
texan79&96
i used to drive a f700 with the 370 i think 4v. if thats the same pattern as 460 could a 370 go into a 79 bronco? what makes the 370 a "truck" engine anyway? it had alot of tourqe it was fun to drive.
fred tyler
