Which is better?
Which is better if not offroading?
  • Duals
    Votes: 0 0.0%
  • Single
    Votes: 0 0.0%
  • Cut-Outs
    Votes: 0 0.0%
  • Total voters
seawalkersee
Outside KCMO
They both have their pluses. I am gonna go with a y-pipe to a single muffler to a single out. It is cheaper and the flow will be about the same. Plus there is no need to try to tune it.
Chris
cowboydan
dual makes hp at top end usually followed by loss in tq. single has a good mid increase, makes more low end tq. but hp drops off near top
king_butt_head
i don't really like to run duals because you have twice the ammount of pipe to smash with a rock or something, but they do sound sweet , i'm thinking of making an ajustable atv disk type baffel behind glass pack's that exit in front of the rear, just my 2 cents
Bradt
Georgia
19876[/snapback]
That sums it up right there. With properly run exhaust one can be just as good as the other. At best one would be only nominally better than the other. You can only push out as much air as you take in. This could go back and forth all day, and still be debating the merits of each.
The best point of a single IMO is that you can run it in a way that you maximize ground clearance. With a dual that becomes much harder since you only have so much space to tuck things away. Add king_butt_head's point to that and you have a strong argument for a single exhaust pipe.
brad
seawalkersee
Outside KCMO
No No No NO NOOOOOOO. Sure they are cool. However you can get just as much power out of a single set up as you can with duals.
Chris
S
sreaminbronco
Dallas
He asked :
"Which is better if not offroading?"
Duals, of course
20000[/snapback]
Yes I did ask that but you never know what the future holds I might put duals on then 5yrs. down the road get a nice crazy idea to go rock climbing or trail riding or something then the duals could get ripped off and its a waste of money or I can get single and tucks it under for better ground clerance so that doesnt happen.
Bronco Medic
Duals sound good, as long as it's done right and doesn't ***** up your motor.
Bronco Medic
