Wheels On A 4x4
88pimpin
Postwhore, Pimpin Ain't Easy
Bozeman, MT
Alright, when it comes to wheels with hubs, I'm not very experienced. So, when you take off a wheel, there's 3 parts, right? (I've taken it off before.) The actual wheel and tire, the hub, and a piece that goes around the hub on the outside of the wheel.
If I bought some wheels for my Bronco, the piece that goes on the outside of the hub that's connected to the wheel, that may not be needed, correct? Like, if I went with the wheels listed below:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP..._PcY_BID_Stores
Now with these, I wouldn't need it either, would I?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP..._PcY_BIN_Stores
I'm new at this, so I'm not sure what all I would do. I want wheels, I'm just not sure about how they would look when I put them on, or if there's any problem with getting wheels to fit on here. I know about the 5x5.5" bolt pattern, so I'm good there.
Any other good deals for wheels out there? I can basically get brand new wheels for under $300. Shipping is usually $80-100 on a set of wheels, so with it included, that helps me out. Around here, I'd spend more than that.
94_bronc
st.paul mn
you dont need to remove the hubs to get the tire off
the 2nd set look almost like factory wheels
the center section of the wheels are removeable on all wheels other wise they couldn't be balanced
if you do any off roading i wouldn't get alum wheels they break instead of bend like steel
b4 you bid on any wheel ask the seller if they have open centers for them most will might cost more
figjeti
