What would happen if....
American Rebel
4x4 Trail Master
Chesapeake, VA
In normal situations, the supercharger will run fine, but if you ever race the bronco, go with a standalone seperate computer management system, that can compensate for the additional boost pressure output by the supercharger.
Because if you race the bronco with the supercharger without any "help", then you risk blowing your motor. Because a performance computer setup will actually ****** timing, and go with a lean mixture to allow more air into the cylinder, resulting in more power.
I've seen a friend blow his motor, but then he's litterally trashed his bronco to a piece of rolling junk. He deserves it, for doing that to a Ford Classic.
lawman212
@-) Your gas gauge will start acting up and will always for some strange reason point to "E". NO matter how much gas you put in the tank or how often. Fuel will just disappear without warning like socks in the dryer.
wyrwulf69
Also make sure that the tranny is up to handling the new found power that the engine will be putting out once you add that supercharger.
eholt80
