what the**&**&^%
miksamak8716
phila pa
hey ya all about 2 weeks ago i started noticing every once in a while when i went to start my 95 full size 5.8 bronco when the engine was cold it would not kick over with a single turn of the key .then a couple of days ago when i tried to start it in the morning it wouldnt stay running unless i had my foot on the gas . after it warmed up it was running fine . .i replaced the TPS and i thought that was the problem the truck really felt good . then this morning the same thing happened it wouldnt stay running unless i kept my foot on the gas untill it warmed up. what do you guys think the problem is. i need this done fast
Tennessee Jed
Autozone sells a maf cleaner, you might try that before buying an expensive sensor. I also read somewhere you can read the resistance of a maf with a ohm meter...I will try and locate it on Google.
M
miksamak8716
phila pa
thanks guys for all your info. ..i also noticed today that if i punp the accelator a few times before i start it i am not having no problem with stalling . i know your not suppose to do this with fuel injection but it seems to be working . what do you think about that?
eholt80
