what size rubber can i fit
highriderW13
texas
i was wondering if i could fit 49 with a 12 in suspension and 3 in body does any body have any idea
ocalabronco
ocala, Fl
total of 15" of lift, probably. it will be snug, and you will be asking ALOT of your 1/2 gear. basically it wont handle much. plan on swapping to 1 ton if you want 49's. either swap to one ton now, or blow up your front and rear and swap in 1 tons later
Bronco89XLT
Medford, NY (Long Island)
look into a solid axle swap. Here is 2 from around my area. Both done at the same shop.
Both ride on 44"s
I am getting my lift done there as well, but only 4"
From talking to the owner, there is a set of 48's waiting for the 89 pictured above
