Weird problems...please help
bronco951995
Hi all....
I've got a 95 ford bronco 5.8L 351 motor. It starts fine, idle's fine, and when I take off at a regular speed, it runs fine. It's when I really get on it, like getting onto the interstate, or giving it a little more punch that it sort of hesitates, and sounds as if it's backfireing....can someone let me know what Ive got on my hands here. It was running fine last week, but the lower radiator hose busted, got that fixed, and now it's running a little bad. A little help would be very appreciated!!!
Thanks
Bryan
Lafayette, La.
oktogo
york sc
did u put any aftermarket intake or throttle body spacer that may be the reason because the computer is putting to much fuel and it loaded up when u hit it if not maby the computer is messed up mabey get the codes checked
BroncoJoe19
New Jersey
Pull Diagnostic Trouble Codes (DTCs) From your onboard computer.
Your engine and transmission are computer controlled.
The computer uses sensors to tell it a number of different things and it controls actuators that push or pull mechanical levers (kinda). If one or more sensors aren't working properly, the computer goes "blind" and doesn't know what to do. If the computer can "see" but one of the actuators is broken and therefore can't follow the commands of the computer; the engine won't run correctly. The computer is preprogrammed with set values for each of its sensors, and each of its actuators. It will run a self check of all systems, like the space shuttle; it will compare its set value(s) to the value(s) it recieves from its sensors, and actuators. If any sensor or acutator is out of the "normal" range the computer will generate a "code." It will generate some codes on the fly, and others will be stored while you are driving. There is a simple method to "pull codes" out of the computer for one to use for diagnostic purposes.
Earlier versions of On Board Diagnostics OBD 1983-1995 can flash the error code to the dash board and can be pulled in one's driveway without any special tools.
Later versions of On Board Diagnostics OBDII some 1995, and pretty much all 1996 and newer, require one to use a code reader or scanner tool.
Some auto parts stores will scan your engine codes for FREE, you may want to call around. Some will scan OBDII but not the older (prior to 1996) OBD systems.
SO here you go...
How to scan FORD on board Diagnostic Trouble Codes (DTCs) in your driveway
Howto Pull Codes 1983-1995 Broncos, Mustang, F series Trucks, Econolines, 302, 351 and more
