Weatherstrip kits
roushracing6fan
Ss with most vehicles its age mine needs new door, window and rear window weatherstripping. I'm finding several companys have them but looking to see if anyones bought them and had good or bad luck so I don't make more work for myself.
I can't tell you who's kit is the best, but I know one place I wil never buy it from again, JC Whitney. I purchased the inner door trim for mine when doing some body work and had the inside trim out, (necessary to install the weather stripping). According to their catalog it was just like the original weather strip. However, it is not and gave two problems:
1. the shape of it is different. If you look at the end of the original stripping for a 83 Ford the weather strip has sort of a bullet profile, JCWs is square.
2. Not being the same shape ment the trim doesn't fit just right since it is designed for the other shape.
3. Not being the same shape causes the doors to have a problem shutting. I've tried adjusting them but tono effect. So the doors have to be slammed so they will latch.
So any way that is my experience with JCW weather stripping.
I used A&M Soffseal
Part Fits Description Measure Price
FD7147 73-79 FULL SIZE FORD PICKUP 78-79 BRONCO WINDOW CHANNEL KIT SET 141.3
FD9010 73-79 FORD (F150-F700) BRONCO PICKUP DOOR WEATHERSTRIPS PR 83.7
FD9364 73-79 FULL SIZE FORD PICKUP 78-79 BRONCO PICKUP WINDOW WEATHERSTRIPS SET 86.4
Good stuff! - their on-line search isn't up-to-modern standards though
also:
B&W
TAILGATE RELATED PARTS 1978-79
D8TZ-9840700-A Tailgate Assembly 1978-79 700.00 ea
D8TZ-9841018-A Upper Tailgate Moulding w/clips 1978-79 30.00 ea
D8TZ-9841018-B Lower Tailgate Moulding w/clips 1978-79 30.00 ea
D3TZ-00407A12-B Upper and Lower Tailgate Moulding Clip Plastic takes 14 1978-79 2.00 ea
D8TZ-9841608-A Tailgate Seal - COMING SOON 1978-79
D8TZ-9841610-A Tailgate Outside at Belt Seal 1978-79 55.00 ea
D8TZ-9841616-A Tailgate Upper Corner Seal - RH 1978-79 18.95 ea
D8TZ-9841617-A Tailgate Upper Corner Seal - LH 1978-79 18.95 ea
D8TZ-9842072-A Tailgate Inside at Belt Seal 1978-79 39.95 ea
D8TZ-98422A36-A Back Window Upper Glass Run 1978-79 40.00 ea
E1TZ-98422A20-A Back Window Lower Side Run L or R 1978-79 45.00 ea
387392-S Back Window Glass Lower Glass Bumpers 1978-79 12.00 pr.
D8TZ-9843000-A Tailgate Hinge - RH 1978-79 85.00 ea
D8TZ-9843001-A Tailgate Hinge - LH 1978-79 85.00 ea
D8TZ-984430A30-A Tailgate Counter Balance Torsion Bar Center Bracket 1978-96 15.00 ea
D8TZ-98431C62-A Tailgate Latch Release Handle 1978-79 67.00 ea
D8TZ-98431C63-A Tailgate Latch Release Handle Stop Bumper 1978-79 1.00 ea
D8TZ-9843732-A Tailgate Scuff Plate 1978-96 40.00 ea
388016-S Tailgate Latch Release Handle Rod Grommet 1978-79 2.00 ea
D3TZ-99439A01-A Tailgate Lower Side Bumpers - on Tailgate 1978-79 4.00 pr.
more in their on-line catalog
R
roushracing6fan
Used the tailgate kit from Bronco graveyard worked well but now my window goes up at an angle sometimes what would this be the bushings or the tracks inside the gate. :wacko:
R
roushracing6fan
I've now replaced every strip on the beast except for the topper. bought them all from the graveyard and they all fit and worked great would highly recommend and bought mostly aftermarket parts. :D/
highboy73
FORDing thru life
morocco,indiana
I've bought 4 complete kits from the grvaeyard,not one problem.no complaints either.I believe the kit was around 250
figjeti
