ft. t bronc
The PO replaced the rear hatch weatherstrip (the long one attached to the body & top that runs around the sides & top of the rear opening) with one from BG. Where it goes around the upper corners, the lack of a molded-in corner causes the strip to slightly lay over - leaving not much compression against the liftgate allowing a lot of water to come in.
Any suggestions? Anyone else have this same problem that they've been able to fix? Any other tips on sealing the rear hatch in general?
