RG75BRONCO
I am experiencing a vibration beginning at 45 mph on. The tires, u-joints are new; both drive shafts have been balanced. The engine and motor mounts are new and all of the brakes have been replaced. The Bronco has a C-4 tranny. When I picked this Bronco up it was not running. It was a total mess. As for diagnosing the problem this is what steps I have taken. At 55-60 mph when the vibration starts I have slipped the tranny in neutral and the vibration stops. I have looked at the rubber mounts on the cross member at the tranny/transfer case and they look good. Is there any other rubber mounts other than the two that are visible on each side of the transfer case? When I put the tranny in reverse I get a hard engagement. The tranny shifts good at all speeds. Any ideas what maybe causing the vibration? I have checked the torque converter bolts and they are tight.
Thanks
Thanks
