Vehicle weight questions
sdom001
Does anyone know how much an 88 stock Full size Bronco weighs? Also the weight of a Ford 302 engine and the weight of a 30 gal. fuel tank. I gonna turn my Bronco into an Electric and need the weights for some calculations.
yo!
GL!
some data for you; also has dimensions
ENGINE, 5.0
Engine 302 (5.0)Weight 460 lbs
Weights, Engine & Dimensions, 289/302 & Boss, 351W, 351C, 351/400M, 332-428, 427 SOHC, 429/460 & Boss Source: by Geoff I at geocities.com
Weight 460 lbs-
more weights in my Bronco site to confirm wt and dimensions, etc.
1988 Ford Bronco FUEL TANK -- 31.0 lbs. . 32 Gal., (31-7/8 x 22-1/4 x 15-3/4), w/ Lock Ring Sets,2" sending hole, No External Vent Pipe, w/o Vent Support in Filler Pipe, (Hol#197-1421)
http://www1.autozone.com/selectedZip,08094...g/selectZip.htm
my 96 Bronco weight came in at 4500 pounds. 302, e4OD, push bar, side rail;; etc.
Curb Weight, 4616 lbs
Curb Weight, lbs. 4616 ----
Bronco Specs, height, width, length, frame length, 66 to 96 Source: by miesk5 at broncozone.com
AND FYI
Brochure, Dealer, Bronco, 89 Source: by fedrelandsvennen.no
yw!
Am greatly interested in your project!..pls post progress or plans here; I did a lot of electric drive tech for da Navy.
GL!
stevedave
