Vaccum
pukfit64
VA
All of the vaccum line in my bronco are destroyed does anyone have any diagrams so i can replace them or advice. i also need to get parts
If you get ahold of Seabronc, he has a wealth of knowledge in this area. He has manuals called EVTM Manual. You can search on ebay for the manual matching your year. I know what you mean about all the lines, I was looking at mine, wondering when they were going to go on me, will **** to replace them.
All of the vacuum line in my bronco are destroyed does anyone have any diagrams so i can replace them or advice. i also need to get parts
There should be a diagram attached to the right front radiator support, on occasion it is on the under side of the hood. Each color coded line on the diagram is for a different function. EFI engines don't have a very complex vacuum system so repair is not nearly as difficult as it is with a carburated engine. If you need help in interpreting it, take a picture and attach it to this thread. Vacuum diagrams differ some what depending on the area that the truck is originally built for. The diagram is laid out like the engine, it should say front at the bottom and that matches the front of your truck.
P
pukfit64
VA
thanks ill look for it and post it if i have problems
Coastersfwb
